Home > Faults & Fixes > 2014 Range Rover Sport stuck in extended suspension mode
pescaglini
United Kingdom 2013 Range Rover Sport SDV6 HSE Stornoway Grey
Hi all,
I have a 2014 Range Rover Sport that when I select normal ride height (or the lower button) it has developed a fault. When pressed, the light will flash and then I immediately get a "pong" noise and the car raises back up to extended "high" suspension mode. For some reason, it won't stay in the normal or lower suspension mode. I have tried removing the desiccant filter but I'm still getting the same issue. Can anyone shed some light on this please? Thank you!
Post #640414 Thu Mar 14 2024 5:10pm
Dave-t
by the desiccant filter do you mean the cons shaped brass bit on the compressor? If not then remove that, its actually the silencer, new ones have a small hole drilled through the bottom and are about a tenner.
https://www.rrsport.co.uk/forum/topic59107.html Joined the X5 45e club
1994 Defender 90 300 tdi
Post #640415 Thu Mar 14 2024 5:13pm
pescaglini
Yes that's right. I removed it completely and run the system for a day but it's still returning back to extended mode as default so not sure that's the issue?
Post #640416 Thu Mar 14 2024 5:17pm
The EAS exhaust valve isn't exhausting. 2012 SDV6 - it's missing a couple of cylinders
Post #640425 Fri Mar 15 2024 12:22am
