Home > Tips & Tricks > Mastic joint?
upbeat
United Kingdom 2009 Range Rover Sport SDV6 HSE Java Black
Mastic joint?
Hi is it wise to fill the gap between top rear spoiler and roof (5/10 mm) with black ( car is black) silicone mastic to prevent water ingress ? Any one done this and did it work?
TIA
Post #640320 Mon Mar 11 2024 12:59pm
TheWojtek
And how are you going to open the tailgate then? Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #640322 Mon Mar 11 2024 1:59pm
Pistnbroke
Spoiler and rear door ( Tailgate) he means as anyone with a brain would realize
Yes I understand the HRW connection is prone to corrosion so this may help. Always listen to old people or when they die you will live on in ignorance.
Post #640324 Mon Mar 11 2024 3:01pm
TheWojtek
As anyone who used their brain to fit some silicone would have realized before even attempting such a feat, the silicone would stick to both the spoiler and the roof, making it a single-use seal.
If the silicone (or any other seal) was applied to a single edge only (either roof or spoiler), it would rub the corresponding spoiler or the roof edge, which would inevitably lead to paint rubbing on this edge. Especially since such seal would accumulate dust and dirt.
The gap between the roof and the spoiler is there for a reason. Regards etc.,
Wojtek
Post #640326 Mon Mar 11 2024 3:38pm
Pistnbroke
Well I just been and stuck my fingers in the gap he is on about ..you do need the tailgate open to see it
https://www.rrsport.co.uk/gallery/albums/u...C_0985.JPG Always listen to old people or when they die you will live on in ignorance.
Post #640328 Mon Mar 11 2024 4:26pm
TheWojtek
Well, this is not a "gap between the spoiler and the roof". This is a gap between the spoiler and tailgate it is fitted to.
I imagine it would take a total spoiler removal in order to do it properly. Regards etc.,
Wojtek
Post #640329 Mon Mar 11 2024 5:13pm
Pistnbroke
See my original post about the use of brains. Always listen to old people or when they die you will live on in ignorance.
Post #640334 Mon Mar 11 2024 6:16pm
TheWojtek
Yepp, it helps writing accurate descriptions and eliminates the guesswork. You may have to take some time to get used to it. Regards etc.,
Wojtek
Post #640336 Mon Mar 11 2024 6:57pm
Water ingress into what part, tailgate, roof panel? looking at my tailgate not sure it would really achieve anything unless the rear screen bonding is leaking along the top edge.
Post #640343 Tue Mar 12 2024 12:12am
upbeat
oops really didnt think about that. Going for a lie down!!!!!!! Whistle
Post #640345 Tue Mar 12 2024 3:41am
