Home > Maintenance & Modifications > Correct engine oil question
SkyWalker wrote:
Thank you for your responses.
To keep things easy, my goal is to just find exactly the same oil as LR is using on the yearly service.
The same as in brand, grade etc. Except for the price..
Already got the original oil filter.
As LR uses Gastrol and the cars user manual says 5W30 C1, I think I´m getting close.
But then you have this specific oil in a Teflon variant. Good or bad?
The oil has the LR engine oil specification STJLR.03.5005, but is this a general approved code for all LR cars or my RRS could have different code?
Thanks again.
STJLR.03.5005 meets/exceeds the old Ford WSS-M2C934-B so it's fine for your RRS. The 5005 bit means it's much lowers SAPS than the previous 5003 and thus is better for your cat and DPF. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #640233 Thu Mar 07 2024 10:59pm
Pistnbroke
Am going to get my boroscope out and see if I can poke it down the cover to have a look. Always listen to old people or when they die you will live on in ignorance.
Post #640240 Fri Mar 08 2024 7:59am
Disco_Mikey
Pistnbroke wrote:
Mickey... are you saying that all 2.7s of whatever year had the weak tensioner mount?
Failures have been noted across all MY's, with 07/08MY most prominent
Post #640264 Fri Mar 08 2024 6:57pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Thank you all for the advise. I guess I can go fwd with this then. Thumbs Up
I'm planning to use the vacuum pump method for the intermediate oil changes.
However this got me thinking. When the oil gets sucked out, doesn't all the "dirt" that has been previously blocked by the filter and still sits in/on the engine side of the oil filter, not get sucked back into the engine again?
And so is it a good idea to first change the oil filter before starting to pump?
Thanks again. SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #640280 Sat Mar 09 2024 2:08pm
Disco_Mikey
Always remove the filter first
It holds around 3-400ml of oil that is released into the sump when the filter is undone Thumbs Up
Post #640287 Sat Mar 09 2024 9:20pm
SkyWalker
Hi DM,
That’s a very good point.
But if you then leave the filter off, does the vacuum pump still work, as there is on opening now and no pressure can buildup?
Therefore I thought to replace the filter first.
This way the oil drops back to the carter, the circuit is closed again, and there is no risk of sucking the dirt out of the filter into the engine. SW
Post #640294 Sun Mar 10 2024 11:31am
The suction vacuum is created in the extraction tool you are using, not the engine, so will not make any difference if the filter is refitted first or not.
Post #640295 Sun Mar 10 2024 11:40am
Disco_Mikey
As above Thumbs Up
Post #640303 Sun Mar 10 2024 4:31pm
SkyWalker
Thanks for all advice.
So today I planned to do the oil change so I parked the car in a level spot and checked the actual oil level before beginning the service.
Overfilled.
Then I remember the incident I had when picking up the car at the dealers after it had it’s service done last August.
They tried to charge me for 7 liter of oil while an oil change is less than 6 liters. Only after he consulted several mechanics incl the service manager they finally admitted the mistake.
But could they stillhave filled the engine with 7 liters of oil and could this have damaged the engine during the 10.000 km I drove the car?
Should I contact LR about this or just do the oil change? SW
Post #640876 Tue Apr 02 2024 9:20pm
I have had mine overfilled by a dealer before now, did you allow the engine to cool before you checked it? after 10,000Km's I don't think you will get any joy from a Stealer, just change it and fill with the correct quantity and grade, also after 10,000 Km's if you were going to do any damage I would have thought it would show and have been done by now. Just measure the quantity you remove to compare if it was a excessive or minimal amount. Are you also saying that is the first time you have checked your oil in 10,000Km's?
Post #640878 Tue Apr 02 2024 9:44pm
SkyWalker
Hi Col,
Yes the engines was cold and I drove it 10 meters to park it level.
Then after half an hour I checked the oil level. And yes it was the first time in 10.000 km.
I red that by pressing Cancel 2 times with the driver side door open you get the actual reading..
Let’s see what is the read out tomorrow. SW
Post #640881 Tue Apr 02 2024 10:28pm
NoExpert
Oddly you’re supposed to check the oil level with the engine warmed up. It’s also usually best to change oil on a warm engine so anything in the oil is suspended and gets drained.
It’s hood and driver’s door open, then press cancel twice to bring up the oil sensor live data. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #640885 Wed Apr 03 2024 6:31am
SkyWalker
I finally did today the oil change with the extractor. Cool
Firstly I drove the car for 10 minutes, parked it level and checked the oil indicator which showed full and OK.
As advised, I then only unscrewed completely the oil filter with a 32 socket but without removing it, so all the oil could drop into the carter pan and the filter could leak out.
The pump took about 7 minutes to take all the oil out.
After that, I changed the filter that now completely was leaked out, so no mess.
To remove the old filter from its plastic housing takes some effort, and the new one has to be pushed in to the same position as to where the old one was sitting.
Then oiled the new o ring on the filter housing before putting it back.
After pouring 5 litre 5W30 C1 Castrol Edge into the engine, I poured 5 litres of used oil into the same 5 litre container. The rest fitted exactly in an 1 litre water bottle.
I guess I must got all the oil out.
Then I poured another 1/2 litre of oil into the engine to avoid overfilling.
Checked the oil level after 20 minutes with the reset knob and it showed 1/2 range and OK.
Drove the car for 10 minutes and after letting it settle for 20 minutes the reading was 2 lines from full so I left it like that.
Thanks all for your advise . Thumbs Up SW
Post #641153 Fri Apr 12 2024 6:33pm
