![]() | Home > General (L494) > 2017 RRS HSE Battery |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 581 ![]() ![]() |
Rjgordon0 Member Since: 25 Jan 2024 Location: Halifax Posts: 11 ![]() ![]() ![]() |
Hi, thanks for that but your link is the same as I’ve seen before & I have no auxiliary battery behind that panel in the boot. There are a lot of electrical components but no battery!! |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 480 ![]() ![]() ![]() |
You will have a capacitor not a battery for the stop start system. It’s the early L494s that had battery for the stop start |
b1ecc Member Since: 19 Dec 2023 Location: North West Posts: 22 ![]() ![]() ![]() |
I have 2016 RRS and only have one battery, changed it last year after the low battery warning. |
Your main battery may need charging up or replacing. I had mine replaced around 2 month ago at a cost of £285 ish. It’s located under the spare wheel in the boot. If you charge your existing battery it will also charge up the capacitor (or battery on early models) |
Nick900 Member Since: 11 Mar 2022 Location: Kent Posts: 89 ![]() ![]() |
I would fit this from Tayna did so about a year ago and works perfectly with a 4 year warranty.
