Home > General > More electrical wiring woes on my 4.2 Supercharged
Markieboy123
United Kingdom 2005 Range Rover Sport Supercharged Stornoway Grey
Following on from my elation sorting the transmission error fault from my previous post.
I thought I would have a go at the Navigation DVD Rom under passenger seat and 6 disc DVD player behind panel at the right rear.
Checking the voltage at the 6 disc DVD player I am only seeing 4 to 5 volts which fluctuates?
Attempted to trace the wiring back by putting a tone on the wiring at the rear dvd player, I cannot hear it in the passenger sil loom but do have it at the Rom DVD nav connector.
Head scratching moment….
Had a cup of tea and thought I would try and trace it out from the BCM fusebox in glovebox, I have 12v on upper part of pin 53 so checked the lower part of pin the wiring leaving the BCM onto the loom and it’s EARTHING out !!!
Put my tone back on at the rear DVD wiring again and thought I wonder if it goes via the drivers sill wiring loom…..I can hear my tone in the drivers side sill after lifting the sill trim, did feel under the carpet and it’s soaking wet.
Ran out of time today but planning to remove the drivers seat plus the sill trim to access that loom I dare say there is a crimp joint there sitting in water.
Wondered how the water got in on the drivers side when the passenger side sill was bone dry??
I don’t have a sunroof so will have a good look when the seat is out.
Post #640001 Mon Feb 26 2024 6:51pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
The A pillar exterior trim is a common water ingress failure point the clips have a seal which let's go
Post #640004 Mon Feb 26 2024 8:07pm
Markieboy123
Thanks
Just seen the YouTube videos of the exact same thing, that’s probably the cause
Post #640006 Mon Feb 26 2024 8:27pm
Lrstaylor
Buy your self a whole new bunch of clips off the bay your gonna need them at somewhere point plus silicon them as well just to be sure.
The other place to look is the top roof gutter seal at the front under the runners.
Post #640007 Mon Feb 26 2024 8:31pm
Markieboy123
Cheers …
Will order the clips, have not seen any information about water ingress at the roof gutters
Post #640008 Mon Feb 26 2024 8:35pm
Lrstaylor
Have a look here it's D3 but the sport has the sames issues
https://disco3.co.uk/forum/pillar-leak-200...oof+drains
Post #640009 Mon Feb 26 2024 8:47pm
Lrstaylor
Another known issue
?feature=shared
Post #640010 Mon Feb 26 2024 8:49pm
There’s a connector behind the trim by throttle pedal.
Loom run down drivers side and under seat probably.
Yeah probably a crimp !
Post #640013 Mon Feb 26 2024 10:08pm
Markieboy123
Thanks for all the pointers….
Will remove the drivers seat and sill trim to check on the state of the wiring along with the A pillar trim
Post #640017 Tue Feb 27 2024 5:57am
Markieboy123
Had half an hour free this morning so whipped out the drivers seat and the sill trim cover to expose the drivers side loom.
Carpet was wet around where my pry tool is in the picture but dry higher up towards the pedals.
I can see the rust corrosion mid way and will investigate later hopefully
Post #640020 Tue Feb 27 2024 11:57am
Markieboy123
Found the problem, corroded connector in the lower A pillar drivers side, looks like a couple of pins have broken off as well.
Will either piece the wiring out to bypass the connector or try and get the connector plus wiring off a breaker.
Post #640023 Tue Feb 27 2024 3:29pm
Quite a mess that connector
Post #640024 Tue Feb 27 2024 3:42pm
Markieboy123
Yep…mounted vertically so the water getting in just ran down the wiring and sat in the connector.
Someone has been in here before and drilled what appears to be two holes in the sill so must have had a water ingress problem before
Post #640025 Tue Feb 27 2024 3:52pm
Lrstaylor
Cut that connector out completly and solder all the wires together bit of heat shrink job done for good
Post #640032 Tue Feb 27 2024 7:17pm
Markieboy123
Re spliced the wiring connector and I am back in business with a working multi play DVD and the sat nav drive.
Took the outer A pillar trim off and found the the water ingress culprit.
The top hole had nothing in it , no lug from the trim so the water easily got in.
Patched the hole with sealant and tape then changed all the clips giving them a bead of sealant too.
Post #640109 Sat Mar 02 2024 11:35am
