![]() | Home > General > RRS 2005 supercharged ..transmission error when drive engage |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4499 ![]() ![]() ![]() |
I've had this exact fault. Switching lights on cured it, and I can't remember the logic behind it
Completely wrong |
Markieboy123 Member Since: 30 Apr 2019 Location: Hornchurch Essex Posts: 59 ![]() ![]() ![]() |
The weather or my assumption?😂 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5080 ![]() ![]() ![]() |
Very interesting your PRND aren’t illuminated.
Yeah it is worth checking those fuses you mention if you aren't getting orange/red lights.
You’re keen to remove that. |
Sorry, my ramblings post Easy to check for power at the gear selector, and the fuse, see which end the problem lies at ![]() |
Called it day when it started to get dark.
Also £2.11p better off from the change found under the gear shifter assembly |
When you have refitted the rear connectors, if you can still see red on the connector it’s not fully inserted
Yeh my old sport was the TDV6 , Mr Khan made me sell that due to the ULEZ expansion.
