![]() | Home > General > RRS 2005 supercharged ..transmission error when drive engage |
Markieboy123 Member Since: 30 Apr 2019 Location: Hornchurch Essex Posts: 59 ![]() ![]() ![]() |
Forgot to add these additional errors come up on scan when you switch on lights and engage gear.
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 ![]() ![]() ![]() |
from the codes you may have more than issue... however, below are what i've seen....
Thanks…
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
It would be worth going around the car ensuring the various earthing points are tight/connected/not corroded. Bad earths can cause a number of error issues.
Thanks 👍
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1902 ![]() ![]() |
No point measuring the voltage at idle, measure the battery after its been standing at least overnight.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
In the wiring loom are splices. This is where 3 or more wires join (crimped) together and get blue tape wrapped around them.
Thanks will check that |
Thanks Andy…. Yes you are right the green wire splice joint was not making contact and my key fob did not work, joined them and soldered now back have a working key fob. Looking to re-splice and solder all the blue tape joints…thanks for the pointer about the red wire, will look for that next…with the passenger seat removed I can access the whole loom in the sil. Will update if the red wire splice sorts the transmission error. |
Respliced and soldered the red wires found in the passenger sill loom unfortunately still have the same error.
Hi All,
Search for the fault code on here or disco3
Thanks Andy
Reading up on a few forums …i believe it’s a voltage supply issue to the gear shifter if the headlight trick works, so will be looking at the fuses on the BCM fusebox.
