![]() | Home > General (L494) > Range rover cover up for the steering rack bolt failures |
jcchief Member Since: 28 Jan 2024 Location: manchester Posts: 9 ![]() ![]() ![]() |
Range Rover chooses profits over safety by not recalling UK cars after using incorrect bolts in the steering rack.
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 593 ![]() ![]() |
How can you check if you own a model fitted with the wrong bolts ? |
If You can get access put a magnet on the bolts if it sticks they are steel.
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 274 ![]() |
uRGHHHHHHH!
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 123 ![]() ![]() |
Could the bolts be exchanged at a regular service easily? or is it a huge job?
Yes would like to know the same, if its a case of accessing the steering rack and swapping the bolts out? |
access makes it a bit difficult but a lot of garages wont touch them because if they shear the bolts while trying to remove them it escalates the cost and time to fix.
