Home > Technical > Drop bar links rear
Pistnbroke
Drop bar links rear
Do the drop bar links vary if you have ACE or not .Variable information in adverts (2009 L320) Always listen to old people or when they die you will live on in ignorance.
Post #639177 Fri Jan 26 2024 11:26pm
erickwan
Malaysia
Nightmare. I guess, supplying the parts outlet with a chassis number is your best bet.
Post #639202 Sat Jan 27 2024 11:30pm
knwatkins
Yes, they are different...
RGD500140 with ACE
RGD000312 without ACE Kev
Post #639212 Sun Jan 28 2024 2:02pm
Pistnbroke
I think you missed the point which is the two numbers seem to be for identical products but one is twice the price of the other ..... Always listen to old people or when they die you will live on in ignorance.
Post #639214 Sun Jan 28 2024 3:46pm
knwatkins
They have different part numbers because they are different parts.
What makes you think they are identical?
Here are the specifications:
RGD500140 with ACE
Fitting Position Rear Axle Right, Fitting Position Rear Axle Left, Rod / Strut Coupling Rod, Length 135 mm, Thread Size 1 M12x1,75, Thread Size 2 M12x1,75
Fitting Position Rear Axle Right, Fitting Position Rear Axle Left, Rod / Strut Coupling Rod, Length 120 mm, Thread Size 1 M12x1,75, Thread Size 2 M12x1,75 Kev
Post #639215 Sun Jan 28 2024 4:09pm
Pistnbroke
Both the specs I have say 126mm
Just been out and measured mine 126 mm not aware they have been changed .
So either they have been changed for the wrong ones or ???
All most ads dont distinguish with or without ESC
Confusing but I guess if both sides the same its ok Always listen to old people or when they die you will live on in ignorance.
Post #639216 Sun Jan 28 2024 5:56pm
knwatkins
Where are you getting your numbers from which suggest ACE and non-ACE are the same? And are you getting your measurements from a retailer or manufacturer?
If you look on reputable manufacturer websites, you will see the parts are different for ACE or non-ACE equipped vehicles. They have different part numbers because the parts are different.
For example:
Delphi...
With ACE
Without ACE
Meyle...
With ACE
Without ACE
Lemforder...
With ACE
Without ACE
There are variations in overall dimensions between manufacturers as measurement points vary (eg. from extremity of the rubber boot or the casting). However, they all have an approximate difference of 15mm between ACE and non-ACE vehicles. With ACE being longer.
Different part numbers, different parts. Kev
Post #639217 Sun Jan 28 2024 6:32pm
Pistnbroke
Wow thanks for all the effort
I am going to measure one owned by the guy next door tomorrow and let you know,
The question is between which two points are they measuring? Always listen to old people or when they die you will live on in ignorance.
Post #639222 Sun Jan 28 2024 8:55pm
knwatkins
No problem Thumbs Up Kev
Post #639223 Sun Jan 28 2024 8:58pm
Pistnbroke
Checked on the friends and mine an they are both ESC and are 132mm between the ends of the bolts.
When weather improves I will have a go at the rubber bushes.
Thanks again for stirling work. Always listen to old people or when they die you will live on in ignorance.
Post #639237 Mon Jan 29 2024 11:12am
erickwan
Malaysia
As far as I can tell.........
Rear:
RGD000312 (without ACE)
RGD500140 (with ACE)
Front:
RBM500140 (without ACE) RHS
RBM500150 (without ACE) LHS
RBM500140 (with ACE) RHS
RBM500150 (with ACE) LHS
Post #639240 Mon Jan 29 2024 2:04pm
