![]() | Home > Maintenance & Modifications > entering with the metal key |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9152 ![]() ![]() ![]() |
The door handles have been colour coded (a 2005 would have grey handles, see launch photo from 2004 from Land Rover themselves) so perhaps someone has put the colour coding covers over the standard ones and you need to remove two covers to get to the hole.
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 ![]() ![]() ![]() |
If you look carefully at the left front door handle you will see that the small (stationary) part has a key symbol on it. You need to remove this cover to expose the keyhole.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
The hole underneath removes the plastic cover.
