![]() | Home > Technical > RRS 2009 Headlight |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 451 ![]() ![]() ![]() |
Are you talking dip or main beam?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9090 ![]() ![]() ![]() |
If the vehicle has the AFS headlights fitted then there is an actuator because it steers the lights when cornering. There is a known failure mode on these where the light "droops".
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 142 ![]() ![]() |
I believe the headlamps work in conjunction with the height sensors and steering angle sensors. |
