Home > General > Newby with a slight problem. |
Hodson91 Member Since: 09 Jan 2024 Location: Washington, Tyne and Wear Posts: 26 |
Hi and welcome, im a newbie too and having a few issues with mine that ive recently bought, problems ive not across even after working on them for the past 10 years.
Mon Jan 22 2024 11:30pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 344 |
Look in the handbook and I am sure you will find there is a key concealed in the fob and a key hole concealed in the passenger door handle Always listen to old people or when they die you will live on in ignorance.
Mon Jan 22 2024 11:31pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4864 |
You can actually buy the passengers side door lock barrel and two key kit from L/R if you get really stuck, it is only the key blades not the fobs as well, but it is stupid money as usual.
Tue Jan 23 2024 12:10am |
TallEric Member Since: 14 Jan 2024 Location: New Forest Posts: 4 |
Ok....so I thought I'd give a quick update on this which may hopefully help others if they find themselves in the same position.
Fri Feb 16 2024 5:34pm |
That was a result mate. I work for and own a land rover and to say the prices we charge are extortionate is an under statement. I for one tend to not use genuine bits unless i have to, saying that when I was practically rebuilding my l320 some of the bits were cheaper from us, although I was getting the bits for cost price. But you did well there mate and im glad you got the service you wanted at a fraction of the price 2010 RRS, TDV6
Fri Feb 16 2024 11:35pm |
