![]() | Home > General > FBH - Diesel dripping from exhaust connection |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5110 ![]() ![]() ![]() |
It's dripping fuel because it has failed to start and you have unburnt fuel which has failed to ignite.
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Hi Col,
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 956 ![]() ![]() ![]() |
Had the exact same issue,, but mine would smoke like mad as the heater was still igniting a lot of the time. I found the ceramic insulator that houses the glow plug at the top of burner core was cracked,, and actually fell to pieces when I stripped it down. 2010 RRS, TDV8
I removed my fbh on Friday, stripped and cleaned it. Luckily the ceramic was intacted still.
That code to me indicates there may be a fault with the flame detector/sensor part of the glow plug, but that is only guess, I don't know for certain. Cheers Col |
Hi Col,
Check you haven't just got a stone lodged between backplate and disc etc. before you get to excited about things.
Yes will do.
