Home > Maintenance & Modifications > Range Rover Sport 2017 L494 Brake Maintanace mode
westallotment
Hi there,
Due to a few mixed messages the following worked perfect for 2017 L494 while changing all pads Front and back. Follow the Rimmer Bros.
* Pop bonnet and remove plastic cover over Brake fluid bottle, slacken top and view the level
* Push the Hazard warning lights button and close all doors
* Key Fob press the Open and Lights button hold for 3 seconds until the Car reaches max suspension (Called jacking mode)
* Press ignition without starting car, Now start To set Parking brake Maintenance mode,
* Press down EPB Button 3 sec and hold, then press Gas pedal all way down and hold 3 secs
* Recycle ignition, switch off and straight back on and wait till dashboard says EPB in Maintenance mode.
* Switch off Ignition.
Garage DIY, Now choc the wheels and put on frame on Axle stands, Place wheels under sub frame for a just in case.
Post #638895 Wed Jan 17 2024 3:18pm
Disco_Mikey
The first steps are not required, just this Thumbs Up
Post #638899 Wed Jan 17 2024 5:35pm
