Home > My Range Rover Sport > Instrument cluster problem
Snooks
United Kingdom 2008 Range Rover Sport TDV6 HSE Siberian Silver
Hi everyone , I need to ask for your advice please ,
I have my 2008 Range rover sport , which I love , the instrument cluster ( YAC 502560) is causing trouble , Ive had it sent to ACelectronics to be repaired , but they cant fix it , So its being sent back not repaired , what is your best advice what to do please ?
Thanks
Snooks
Post #638890 Wed Jan 17 2024 1:01pm
Well first don’t post in the pictures subsection.
Post in the top 4 as they get read.
Go have a look on disco3. Link at the bottom of the page. Should be info on there
Post #638901 Wed Jan 17 2024 9:33pm
woodsie
United Kingdom 2010 Range Rover Sport Supercharged Autobiography Stornoway Grey
Welcome to the forum, do a search on here loads of information seems to be quite a common problem particularly for 2007 year models and maybe later models now as they age. Wink
Post #638931 Thu Jan 18 2024 8:01pm
ellzeez
Australia 2007 Range Rover Sport TDV8 SE Atacama Sand
Old thread yes but for those stumbling across this in the future. I had the classic failing cluster symptoms in my 2007;
- hazard lights flashing (externally but not showing on the cluster)
- head unit "System Fault, Shutting Down"
- climate control panel shutting down
- suspension fault 'vehicle lean'.
Pulled it out, got a local electronics guy to look at it, found a few dud solder joins on the connector but didn't fix my problem. Sourced a used unit from a 2009 with 150,000 less k's than mine. It also had the new part number and what appeared to be a 2016 manufacture date (big win) for $300 and with the help of Patrick at Gap got it installed and working fine since. 2007 L320 RRS TDV8
Post #645588 Tue Dec 03 2024 1:00am
Disco_Mikey
Essex Recons Thumbs Up
Post #645590 Tue Dec 03 2024 7:59am
