![]() | Home > General > Rear seatbelt mod |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477
As the belts get older the fabric gumms up with dirt ....clean full length with detergent dry and spray with silicone spray ( not wd40) they will then run back fine and you wont get the rattle Always listen to old people or when they die you will live on in ignorance.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
My MY08 TDV8 had a plastic clip on a bit of webbing that held the rear belt in place to stop it moving around or getting caught behind the seat when it was folded down to make a flat load bay. Just another of those really good little details I miss on my MY12 SDV6 that I had on my MY08 TDV8. I assume it was deleted to save JLR a couple of quid. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
Never did really workout why they did away with that clip on the facelift cars, as said probably saved 10p per vehicle. Fortunately I don't have rear seat passengers very often these day's so just leave mine plugged in.
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167
Eh up all
The problem is I don't think they are listed separate in the parts list as they are sewn into the seat trim, but not totally sure on that one, so you may have to find a a earlier model in a breakers yard to get them.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
Yours will only be a problem if you put the seats down |
Eh up all
| All times are GMT |
