![]() | Home > Maintenance & Modifications > Lack of power?!? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5110 ![]() ![]() ![]() |
I don’t think cruise control should make it change down ? And drive fast up hills ? Or do you know it’s capable of that ?
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 342 ![]() ![]() ![]() |
Hi Andy - I didn't receive any fault codes on the dash. I do this France to Spain trip every year and haven't had this problem before. Usually going up steep hills in cruise control it would change down at some point to maintain the set speed. Could the problem be something to do with torque control? My concern is whether I need to have it sorted before the return trip - hopefully not!! Andrew Kennedy |
IF you have a fault code reader, read them and clear them. |
I don't have a fault reader. I have just looked online and can see its a handy gadget, however, my knowledge and understanding of car mechanics is nil. If a code reader told me what that problem was, I doubt I could do anything about it - changing the air and pollen filter is about my limitation - unless its something practical.
Andy - perhaps I missed the point - if I were to get a code reader, should I had a problem in the future, with the code someone on the forum might be able to tell me what the problem was. I can see there are various on the market, can you suggest a model that would best suit a 2006 Sport. Andrew Kennedy |
Exactly. If you had yellow lights or messages on the dash it could have logged a code.
mark8815 Member Since: 12 Nov 2023 Location: West Yorkshire Posts: 22 ![]() ![]() ![]() |
i got a used Icarsoft one off marketplace for £50, works spot on for what i need it for. |
Lack of power or lack of downshifting is the real question here. The fact you whacked the accelerator and the trans didn’t kick down makes me think you need to be looking at the transmission. Have you ever had it serviced? May have a dead/clogged solenoid that’s not doing its job. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thanks for yous No Expert! Frankly I don't know if the transition has been serviced. I take the car in every year for a general service - when I get back from holiday I'll take it in to be looked at.
