![]() | Home > Technical > Adding two stroke oil to fuel. yes/no |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Does it mean the two-stroke oil fixes a faulty engine? No. It can not fix anything. What it does, it masks the underlying issue for a while. More on how it does it below. BTW does the MOT Station sell the Whynns or 2-stroke oil on the premises? Side note 1: the 2-stroke engines were effectively banned from widespread use in automotive mostly because of their sevenfold 4-stroke hydrocarbons emissions. Those hydrocarbons come from the oil, not fuel. The fuel is notably burnt better - this is why 2-strokes are in general more efficient compared to 4-stroke engines. Sadly, a fair amount of the oil is emitted as unburnt vapour. HC emissions will always be higher in an engine that runs on a mix of diesel fuel and 2-stroke oil, because with the 2-stroke oil in the fuel system you introduce way more hydrocarbons into the combustion chamber and this oil will not burn even in a petrol 2-stroke engine (it would be useless as a lubricant if it would), yet alone in a diesel that has way lower combustion chamber temperatures.
Nope. This is anecdotal evidence. We don't know how many owners were turned away for the reason of faulty engine. We don't know if any of them actually used any additive. We don't know if they did anything else to their engines. We don't know how many of those who passed for the second time did exactly nothing. We have no blind sample and we have no control group. This is textbook anecdote (and biased _opinion_ at the same time). The science that leads to know the unknown relies on precise data that is already known (or even better - a controlled environment). This here is a tale of unknown number of some cars we have no idea if serviced in the meantime or not, in some MOT station. I do not try to tell that that didn't happen. What I am telling is that there is zero statistical relevancy between a random MOT station that tells people to put whatever into their tanks and 1.47 billion vehicles in the world (as of end of the 2023).
Oh, they do. 2-stroke oil with all the HC content will strain the DPF and will shorten the lifespan of the cats. The cats are designed for 15 years of use by an average Joe, so they are only able to contain as much HCs. Once you introduced more HCs into the fuel system, you get more HCs in the exhaust - especially if it is the 2-stroke oil, designed to not burn in the combustion chamber. So your cats designed to trap unburnt HCs works overtime. It is only efficient at around 95% for the most of its life anyway and will light the CEL if its efficiency drops below 93%, Introducing even 1% more of hydrocarbons into the fuel system will shorten the cat lifespan because maths. BTW a 1% drop in cat efficiency is more or less equal to 50% increased emissions. Now since the manufacturers tend to overengineer things a bit and err on the side of caution, an average Joe putting 2-stroke or whatever into his tank may never experience a cat malfunction. His vehicle will never pass the 300k or 400k-mile mark when the cat is technically dead. So he will sure as hell say "I do it all the time and nothing happened!" - which, again, is anecdotal evidence not qualifying to anything close to a scientific method. Also, the vehicles "ran for the past 30 years with 2-stroke oil added" are so primitive compared to a modern engine (see the "used frying oil" example somewhere in this thread, I bet it has got a mechanical injection pump) that their emission systems, if they exist, may even not be designed to warn the owner of the reduced functionality. So the average Joe (and their friend, and the friend of a friend who all been told the wonder effects of putting 2-stroke oil into their tanks every fillup) will pollute more but hey, why care for another human with lung cancer when the NHS is literally drowning in all this government money. Side note 2: an engine treated with 2-stroke oil into the fuel system will certainly make an impression of running better. Plain and simple: more HCs, more power. What is getting burned in an ICE are hydrocarbons, that what fuel consists of. And some of the HCs contained in this oil will burn. The older the engine, the better feel it will have. Some of this oil will stay on the cylinder walls, improving compression and combustion and making the engine work even better. This is not a fix though, this is masking the issue with a band-aid and as any car mechanic knows, this is a recipe for an even bigger repair bill in the future. And since the 2-stroke oil is designed to withstand the burn process and exits the exhaust as unburned HCs, which will clog the cats, will pollute more and will have an impact on the combustion process (most likely the combustion temperature will rise, which can spell trouble, especially for modern engines). Now admittedly - 200cc per 80 litres tank is a small value. So perhaps it is actually OK to say "knickers, it will not do the engine any harm for sure"? Maybe right. Maybe not. But if we put this very argument au contraire it actually becomes proof that the 2-stroke oil is not able to do anything good to the engine. So long-term it is a harmful placebo. Short-term it is a desperate temporary measure.
Putting 2-stroke oil and fuel additives in the same basket is a gross misconception. These additives are something completely different from the hydrocarbons found in 2-stroke oil, resembling rather a decent standalone diesel additive. They contain mostly glycol alkyl ether, aromatic ethoxylated surfactants, with addition of cetane number enhancers, injector detergents and lubricants. As little hydrocarbons as possible. There is a rather thorough analysis (longread warning) here https://dieselnet.com/tech/fuel_diesel_additives.php Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5053 ![]() ![]() ![]() |
Out of interest how many Covid jabs have you had ? |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1890 ![]() ![]() |
Excellent post from Wojtek whose posts I really respect.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9066 ![]() ![]() ![]() |
I've never run 2SO in any of my diesels and none of them have had any issues, including ones that were in the 150-200k miles range. So what does that prove according to your logic? An aftermarket additive such as Millers is similar to the stuff the fuel companies put it - it's a chemical cocktail designed to clean the fuel system. 2SO isn't. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed Last edited by RRSTDV8 on Sun Jan 07 2024 6:59pm. Edited 1 time in total |
Likewise, a great post. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 441 ![]() ![]() ![]() |
No one has mentioned which type of two stroke oil ,,,there are ones for air cooled 2 st which run at a higher temperature and those for water cooled outboards which run lower more like our cars.
https://www.disco3.co.uk/forum/2-stroke-oi...hlight=2so
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 ![]() ![]() |
I'll just answer this one (life's too short for the rest & I don't really think you read my post correctly anyway.) The vehicles in question had no other work done to them & FWIW the garage don't sell two-stroke or Wynns. 2006 RRS 2.7 HSE. |
Is this an educated guess, evidence-based knowledge, anything in between? Assuming you have thorough knowledge of all the vehicles you mentioned as proof of your statement (unlikely), my explanation still stands. Adding 2SO will make an impression of a suddenly healthier engine. Heck, it may even be that sealing the leaks between cylinder walls and piston rings offsets the added HC content for some time and for a tank or two it will run cleaner. Band aid on a broken leg.
I honestly can't decide if suggesting a band aid on a broken leg for free is worse than pushing it for money or not.
Quite the contrary, I did, which is why I gave you a detailed answer ranging from what does actual science think about "empirical evidence" as provided, to a pro/contra of the 2SO oil in a modern engine. I am not disappointed you waived your opportunity to contest applied logic and scientific facts, though. That was expected.
Elegant and respectful, thank you. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
I tend to refil my tank when it gets about half empty - I put around 125ml in. 2006 RRS 2.7 HSE. |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 349 ![]() ![]() ![]() |
The main reason I added 2so to our tdi engines was to prevent the build up of ring gumming as I ran it mostly on svo mixed with 5% petrol or miss fuel from my mates garage.
Jellis39 Member Since: 21 Apr 2019 Location: Melton Mowbray Posts: 74 ![]() ![]() |
I do it, makes a difference and wouldn’t bother if it didn’t. Only been involved in engines etc for 25 years so may be wrong. |
