![]() | Home > General > Difference in steering |
| kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53
normal. have a go in a 494 next & the 2012 will feel heavy. |
| wiztaz Member Since: 28 Dec 2021 Location: Essex Posts: 41
I just thought the L320’s would all drive the same but guess I am wrong. |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
There are proably a few variables really like brand and tyre pattern, tyre pressures, has the power steering oil ever been changed etc,etc. could try a bit of wd40 on the steering shaft u/j's but would have thought with u/j's steering would be a bit stiff. Can't really remember if I noticed any difference between my old pre-facelift and facelift L320 cars.
| Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 217
As Col mentioned check the knuckle on your steering linkage from wheel column to the rack.They do seize up and get tight .I make sure mine is well greased up with white grease in my case sprayed it into the Joint. |
Thank you Col, thank you Iomegas. I will try your suggestions and see how that goes. I was just curious if anyone had noticed a difference in steering between the pre-facelift and facelift or if RR had made any changes to improve the steering in the facelift? |
| All times are GMT |
