Home > General > Rain coming in!
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Rain coming in!
2006 Sport. Suddenly there is a leak allowing water to come in on the side/head lining on the front passenger side (see picture).I'm well aware that finding the source of the leak is a difficult one. I have used a watering can in various exterior possible entries - not resulting in water coming in - also put the hose over the complete front of the roof - no sign of water......however after leaving the car for a while....in comes the water. Another problem is I am just about to go off on holiday and need to try, if only a temporary solution, to cure the problem. Any creative ideas out there?!?
 Andrew Kennedy
Post #638448 Sat Dec 30 2023 3:00pm
Is that the windscreen A pillar?
Your better off with it removed. (torx bolt behind airbag logo).
Then use a hose to see if you can see more water behind.
Post #638449 Sat Dec 30 2023 3:04pm
andrew kennedy
Thanks for that Andy. As I am off to Spain tomorrow. What if I were to put some Blue Tack round the pillar? Do you think that might sort it out pro-tem? Andrew Kennedy
Post #638450 Sat Dec 30 2023 3:14pm
andrew kennedy
Andy - I think I misunderstood what you meant by "pillar". I think now you were referring to is the pillar between the two side windows? My leak is on the pillar running up at an angle from the bonnet up to the car roof. Does that one simple prise off? cannot see a way of getting if off. Andrew Kennedy
Post #638452 Sat Dec 30 2023 5:44pm
skid1963
that's the A pillar
pillar between the 2 side windows is B pillar
Hope that helps
 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged - Gone
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #638456 Sat Dec 30 2023 6:17pm
Just pop out the small oval airbag grommet, unto torx headed screw underneath, pull out a little as there are a couple of plastic pins that locate in the bodywork, lift slightly should then come off. The torx screw will proabaly stay in the trim as it is gripped by a couple of plastic lugs.
Post #638458 Sat Dec 30 2023 9:14pm
The windscreeen pillar is held on with one bolt under the airbag logo. As previously stated.
The only temporary thing I could think of trying is some electrical tape in the roof gutter ? Over any roof rack holes? Long shot.
Post #638459 Sat Dec 30 2023 10:13pm
Could remove the trim and get someone to spray a hosepipe over the area outside while looking from inside, might prove something.
Post #638460 Sat Dec 30 2023 10:25pm
andrew kennedy
Had one hell of a storm last night and the water is really coming in now. I'm going to tape over the factory fitted roof rails in the hope that will solve the problem. When I get back (or maybe when I am on holiday) I'll take the rails off and have a look round - cant find anything online re how to take them off but I presume it just a matter of taking off the black round blanks and taking off a couple of screws???? Andrew Kennedy
Post #638468 Sun Dec 31 2023 8:19am
andrew kennedy
Water "coming in" saga continues..........
I taped over the factory fitted roof rail and rain is still coming in. Sat in the car with the Sun Roof chosed, put my figure up into a recess and there was a pool of water - so have now taped up all around the exterior of the Sun Roof.
Is there, hopefully, some form of outlet (rubber tube?) in the body of the Sun Roof for allowing water to drain off? Or perhaps I have to consider changing the rubbers? Andrew Kennedy
Post #638470 Sun Dec 31 2023 1:27pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Iv just done my sunroof drain on passenger side where water was filling up the Foot well.
Yours is st the top of the A pillar trim usual suspect is the drain tube at the top end sunroof drain has come away, split or drain tube blocked causing the water to fill the drain tube and back drain.
Or like on our d3 I know different car but same issue the roof bar strip at the front needs lifts up and resealing at the very front where it appears to never have been welded in the factory and the sealant breaks down over time. Scrap away as much as you can and reseal test your drain tubes to make sure there nor blocked YouTube is your friend here.
Post #638471 Sun Dec 31 2023 3:03pm
Sunroof drain tubes probably need sealant applying and putting back into the sunroof tray.
Post #638472 Sun Dec 31 2023 3:30pm
Not the best picture, might have to drop headlining a bit to get to it.
Post #638477 Sun Dec 31 2023 8:32pm
andrew kennedy
RAIN COMING IN ...solved! One of the drain pipes situated in the "sunshine roof" cutter had become 'kinked' and was allowing water to come in on the head lining near the door pillar. Andrew Kennedy
Post #638646 Tue Jan 09 2024 5:00pm
Lrstaylor
Result well done on finding that
Post #638648 Tue Jan 09 2024 6:09pm
