Home > General (L494) > Headlight aim too high??
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Hi , does anyone get flashed by other drivers at night with them assuming the high beam is on? I get flashed most days if I’m driving at night. The headlights are self leveling I assume so the car decides what’s right height wise? Surely the car will be checked that the height is correct when the MOT is done? I was thinking if this is checked at MOT the car will be in access mode so the headlight aim will be lower. Do I need to alter the aim somehow or is it just how the car is?
Post #638383 Thu Dec 28 2023 5:58pm
b1ecc
United Kingdom 2013 Range Rover Sport SDV6 HSE Izmir Blue
I don't think it's anything you need to worry about.
If you have access mode activated then the headlights will automatically adjust.
At my MOT garage the engine is left running as it moves from ramp to headlight/emission test to brake rollers, all this is done at normal ride height.
You could also disable access mode prior to MOT.
Post #638388 Thu Dec 28 2023 7:31pm
Johnrrs
Disabling it before the MOT could be a good idea.
Post #638397 Thu Dec 28 2023 11:55pm
Farmer Chalk
This may help….really easy to lower them…
https://www.rrsport.co.uk/forum/topic42581...ights+high
Post #638398 Fri Dec 29 2023 12:12am
Johnrrs
Thanks, just read your post. You say you set the height of yours facing the garage door. Is there a correct height I need to be measuring and marking from the floor?
Post #638403 Fri Dec 29 2023 6:32am
Farmer Chalk
Unfortunately I don’t have any measurements however you can easily see them being turned down … gave them a few tweaks which solved the problem but I could still see clearly and I stopped the flashing headlights from oncoming motorists.. never had an issue with MOT either!
Bit of trial and error I’m afraid…
Post #638426 Fri Dec 29 2023 8:01pm
Johnrrs
Post #638429 Fri Dec 29 2023 8:06pm
