![]() | Home > General > What to check before buying a range rover sport |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5144
What sort of year are you looking at. The big or small one?
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
TDV8 has a chain, not a belt, just to add to the confusion.
| camfran29 Member Since: 25 Dec 2023 Location: UB10 Posts: 4
I thought about 30.SD V6 HSE black auto 4wd
| TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 752
Always worth checking the car out with a code reader, since suspension faults are very scary and deemed extremely expensive, while in most cases they can be sorted out by a smart mechanic for far less than the negotiable discount for "faulty suspension, will take it for parts". Regards etc.,
Hello,
The 1st question is "depending on what is at fault". The suspension compressor replacement would be 3/10 in my book, 4/10 if you don't replace but rebuild the original unit. Valve blocks would be 4/10, airbags 5/10. All these assuming you have access to a lift, tools and have general mechanical capabilities.
Both the 2.7 and 3.0 diesels suffer from crank shaft failures. The 3.0 from what I have seen failed early in its life (30K miles)
My 2012 SDV6 has 151k miles. So it's not necessarily an issue if the history is complete and comprehensive. If you look on the forum, there is a thread with owners and their mileages. There are SDV6 with over 200k miles on them and 2.7 with 300k++ on them. Yes, they can snap cranks, no one knows which ones will so if you buy a V6 diesel it is a risk albeit a small one. Other than that risk, if the vehicle is looked after properly (not LR main dealers!) then they can be reliable and long lived. Yes, they will need stuff doing once they're several years old - all cars will, generally speaking - but if you have a decent specialist garage and are prepared to do work when it needs it, then it can give you long service. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thank you very much for your support.
| Mozart21 Member Since: 24 Feb 2024 Location: Lincolnshire Posts: 2
Has anyone produced a checklist for L494 purchase used. I’m looking at a 2018 or 2019 around 40-60000 miles. Any thoughts welcome. Thank you |
| JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 435
Bear in mind insurance and tax will be a lot more expensive with the later cars. It’s worth getting an insurance quote and also seeing what the tax is.
| Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 124
For my two - penneth.
| Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 358
Your sanity.. ....that is all. |
Thank you J-Cj and K-t. I suppose a bit like that extra drink: one knows one shouldn't but want to and the pain and hangover tomorrow is a different story. I have had two L322 FFRRs, a Disco I and two Disco IIs. I currently have a Defender 90 Td5 so know a good local mechanic on first name terms and have had both trouble free motoring and an L322 total engine failure. I have had complete brake failure on a new BMW 3 series and a gearbox (twice) on an Audi Q3.
| All times are GMT |
