| RRSPORT.CO.UK | ||
|  | Home > Technical > Hard Suspension / variable damping |
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1924    | What wheels and tyre size are you running? 2026 P460e Autobiography on order
|  Wed Dec 20 2023 12:06pm |
| aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 50      | 19in is the smallest I could fit over the later brakes, and they came with 55 profiles (should be 50).
|  Wed Dec 20 2023 2:32pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | The RRS's suspension is much firmer than something like a P38 would be. 2012 SDV6 - it's missing a couple of cylinders
|  Wed Dec 20 2023 3:46pm |
| aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 50      | Slight understatement  | ||
|  Wed Dec 20 2023 5:33pm |
| TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 752      | The variable dampers, if they break (and they eventually do) will default to the “hard” setting. Actually, just one is enough to give an impression of overly hard suspension.
|  Wed Dec 20 2023 5:49pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Are your dampers original? How many miles have they covered? 2012 SDV6 - it's missing a couple of cylinders
|  Wed Dec 20 2023 9:37pm |
 Aha, this is the sort of info I was after. Any way of checking that would be obvious. RRSTDV8 - Vehicle is only at 70,000 so original dampers I would have thought. Alan Series 3 109 Classic 2-door 101FC GS Three P38 4.6L RRS mk1 2012 | ||
|  Thu Dec 21 2023 12:30am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Have you actually had the vehicle read for fault code's, or have any warning lights showing, as the system consists of slightly more than a couple of wires going to a solenoid in the damper, there is over a hundred codes attributed to the ADM module so it might help. I had my old P38 for over ten years prior to having both a pre-facelift and facelift variants of the Sport although only facelift one has CVD obviously, there is no comparison in ride level, I would describe the P38 ride and handling more to wallowing around in a old boat. Have you driven any other Sport's with the system to make a comparison?
|  Thu Dec 21 2023 1:46am |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477      | When the dampers go soft a pothole will throw you into the next lane so be careful.
|  Thu Dec 21 2023 8:32am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | I run mine at 36f / 39r and don't have issues. So if one finds the car struggling with potholes then that might suggest an issue with bushes or dampers. 2012 SDV6 - it's missing a couple of cylinders
|  Thu Dec 21 2023 9:05am |
 Could be the good old lower arm bushes at the front. 70k miles is around the time they often need looking at. I know mine felt very different after having the lower arms replaced a few years ago. Much more "magic carpet" as one might expect for the brand. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed | ||
|  Thu Dec 21 2023 9:06am |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477      | I have new rear  shocks and  front sus arms and run at 32 psi all round Always listen to old people or when they die you will live on in ignorance.
|  Thu Dec 21 2023 9:31am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | 32psi all round? Yikes, that's very low for the rears. What tyre / sizes are you running? 2012 SDV6 - it's missing a couple of cylinders
|  Thu Dec 21 2023 10:11am |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477      | 255 55  19 Always listen to old people or when they die you will live on in ignorance.
|  Thu Dec 21 2023 10:14am |
| Posting Rules
