Home > Technical > Charge light |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
I would say 13.8 - 14.2 is too low,,, should be a constant 14.6/7V . My alternator output began to drop to the 13.8 mark just before it failed completely. Really need to check the current output as well though, not just voltage 2010 RRS, TDV8
Fri Dec 15 2023 5:39pm |
stephen_dalton Member Since: 22 Dec 2019 Location: st helens Posts: 8 |
Ok thanks pal |
Fri Dec 15 2023 5:41pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 344 |
If the charge light is on it means you have a fault ...it does not mean you have no charge but charge can be reduced . Best get a new alternator Always listen to old people or when they die you will live on in ignorance.
Fri Dec 15 2023 9:44pm |
