Home > General (L494) > Error Code 1CA20 Help |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
Is the code correct,,, couldn't be C1A20-xx ?? Certainly compressor related,, what brand of reader did you use 2010 RRS, TDV8
Mon Nov 27 2023 7:39pm |
41664166@online.no Member Since: 01 May 2015 Location: Moss Posts: 127 |
Hi, used a Launch tester, will try with our Texa at our garage, to compare the error code |
Tue Nov 28 2023 4:24am |
Dartanjang Member Since: 07 Jan 2018 Location: Mälardalen Posts: 6 |
The code generally says that the pressure in the reservoir is rising too slowly when the compressor is running. For me when this happened in my D4, the cure was compressor replacement.
Tue Nov 28 2023 10:35am |
Today I read out the same code on our Texa, started the car on our lifting jack and then heard a hiss under the car on the right side, it turned out that there was a leak in the nipple into the air tank, I think this is the cause of this problem, we'll see if we can get this sealed tomorrow |
Tue Nov 28 2023 6:39pm |
Hello again, it turns out that there is a rusty hole in the air reservoir itself as well, where can I buy a new tank |
Wed Nov 29 2023 4:59pm |
Site sponsor,, advancedfactors bound to have one 2010 RRS, TDV8
Wed Nov 29 2023 8:48pm |
Then I ordered a new air tank, let's hope that solves the problem |
Fri Dec 01 2023 4:50pm |
Hello again, there was a new air tank in place, deleted all fault codes, long drive and everything works again as it should. Delicious, Have a nice weekend everyone |
Sat Dec 09 2023 6:40am |
Hello again, we have used the car for 2 days without problems, but today a yellow triangle appeared again. Then took and read out the following error codes: U0001, B1D02, C1A13, C1A99, U0421 Anyone who can have an idea what could be wrong, Thanks and suggestions are welcome |
Thu Dec 14 2023 5:33pm |
When I had the same inital fault code as you (C1A20) I needed to change the compressor. After having replaced the compressor I directly received the C1A13 code. It turned out that the exhaust valve of the new compressor was sticking, which evidently was a common issue. So I swapped the exhaust valves between the old and the new compressor and then everything worked fine.
Fri Dec 15 2023 10:56am |
Hello again, have now driven for a few weeks without any error codes, but yesterday the yellow triangle came on again, I read out error codes today, and the code that is there all the time and does not go away is C1A99, does anyone have any suggestions as to what it is may be |
Sun Jan 07 2024 8:15am |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 211 |
Google says it is Air Suspension Pressure Sensor. Loads of info about it but not familiar myself. |
Sun Jan 07 2024 1:08pm |
Where is the sensor located ? |
Sun Jan 07 2024 1:37pm |
Have then had the codes read out at a workshop, and it shows CA99-1C, Any tips on what it could be |
Wed Jan 10 2024 9:19am |
