Home > General (L494) > 20" wheels fit over Brembo brakes?
Generally speaking a deeper sidewall will give a slightly more comfortable ride just how noticeable is a another thing. You could run 275/50 x 20" which would probably be a better ride than 275/40 x 22" both are the same overall diameter, 275/45 x 21" some where in the middle I guess but still same overall diameter as the other two, personally the 21" would be my choice.
Post #635481 Thu Aug 31 2023 9:29pm
TheWojtek
What Col says. For a given type of tyre, more sidewall = more cushioned ride. Also more sidewall = marginally lazier steering, but there is no way to ever really experience this in such a narrow size window. So, here it is:
Specification  Sidewall  Radius  Diameter  Circumference  Revs/Mile  Difference
275/50-20         5.4in  15.4in    30.8in         96.8in        654        0.0%
275/45-21         4.9in  15.4in    30.7in         96.6in        656       -0.3%
275/40-22         4.3in  15.3in    30.7in         96.3in        658       -0.5%
Over 1 inch of additional sidewall with a 20" but a relatively small loss of sidewall on a 21". All sizes within unperceivable difference of circumference, so no speedo adjustments. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #635485 Thu Aug 31 2023 10:10pm
MadJax
Australia 2013 Range Rover Sport SDV6 HSE Santorini Black
I recently picked up a 2016 SDV6 HSE and it came with 22inch wheels.
A mate also has a 2016 SDV6 SE with the Red Brembo callipers. But it came with 20inch wheels.
Now he has upgraded to 22in the 20in wheels have ended up with me.
I want to use them when I go off-roading or tow long distance as I think they will be better.
But at least they fit.
Post #637676 Tue Nov 28 2023 10:28am
AndyCHO
Australia 2010 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
I changed my tyres to 275x45-20 and the difference has been quite dramatic.
The ride quality has improved immensly and my speedo now reads spot on with my GPS speed which I dont mind.
the ride quality can also be attributed to the tyres... I went from Kumho to Pirelli Scorpians. Handling, noise level and wet performance has been outstanding so far and with 10,000 km on them there is so far no discernable wear.
I havent had time to fit my Brembo's yet as it has been super hectic for the last 6 months but over the Christmas break I should get them done... I even invested in a pressure bleeder (a cheaper one but better than nothing).
Post #637705 Tue Nov 28 2023 10:19pm
