![]() | Home > Technical > No Crank ..possible reasons? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
My D3 did this shortly after its rebuild, 3 ½ years ago
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1556 ![]() ![]() ![]() |
Don't you just love these cars? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9100 ![]() ![]() ![]() |
Land Rover electrical fairies. They just love a game of random symptoms now and then. |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 459 ![]() ![]() ![]() |
Having a lot of experience with classic Jaguar my first call was the battery ...after a nights rest it was 11.7v which is not good . So tested with my electronic tester and then ordered a new one Internal resistance and CCA were down,
Might be worth checking the alternator functionality once you have a new battery in. Perhaps the alternator is tired or is the battery issue just down to age and short journeys taking their combined toll? 2012 SDV6 - it's missing a couple of cylinders
When you say the alternator goes weak you mean the voltage regulator voltage drops. this was a problem with the Lucas ACR 15 alternators but my vehicle has two batteries and the aux one was at 12.7v
It's not just starting loads, it's lots of electrical loads on these vehicles. Certainly, doing short journeys causes battery drain over time - plenty of posts/threads over the years supporting this with anecdotal evidence.
Sad to see you re iterating these myths about alternators.
Read what I said. The alternator has to deal with heavy loads and recharge the battery. But also, the car discharges the battery in several ways when the engine isn't running. No engine, no alternator. No alternator, battery being drained. Do that enough and you end up with a low battery. Low battery throws up errors on these vehicles. 2012 SDV6 - it's missing a couple of cylinders
So you are saying if you leave it for 4 or 4 days you need a battery maintainer connected. Always listen to old people or when they die you will live on in ignorance.
If it's used for short journeys all the time, or if left for a long period, there is a risk of battery drain. LR even put this in the owner's manual, saying to frequently check the battery charge along with info about charging the battery. If I was using one just for short journeys I'd be attaching a smart charger at the weekend now and then just to make sure the battery is kept topped up/in good condition, especially in the winter (remembering about charging frozen batteries, of course!).
