![]() | Home > Maintenance & Modifications > Wiring fog lights for DRL’s? |
Has anybody setup their fog lights to work as DRL’s?
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Keep in mind this is a setup that does not fulfill the definition of DRL and will have you fail our local MOT and get you stopped by police. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 451 ![]() ![]() ![]() |
Just passed MOT on Jaguar xk8 with this set up.
Can't help if UK MOT technicians are underperforming. This is anecdotal evidence anyway and does not change the rules.
just checked your link and it says no longer in force .
Oh, you should've clicked further until arriving at https://eur-lex.europa.eu/legal-content/en...32019R2144
UK motorways very very crowded compared to say france Always listen to old people or when they die you will live on in ignorance.
I had been driving countless times in the UK and do not find them motorways any more crowded than Berliner Ring, A8 Karlsruhe-Frankfurt, A8 to Nice or A13 Brenner Autobahn. This is irrelevant to topical DRLs anyway. Regards etc.,
Considering the hokey @$$ BS I’ve seen people getting away with for DRL’s here in Poland, I’ll take my chances. One guy had LED strips for home interior wired up and had been there long enough to turn yellow and connections rust. If that garbage passes a Polish vehicle inspection I could shove two crappy flash lights in the fog light holes and pass.
A bit more information on those DRL stamped lights would be helpful ..did you get them on e bay ?
I used the Valeo LED fog lights out of a Citroen. They have the same mounting pattern as the 2010-2013 L320’s, but the adjustment knob is further forward so had to trim a little inside the bumper.
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
I didn't go for any fog provision, pure DRL, but both are available from
Okay, I read this and it makes some sense, but not totally. It appears I lose the fog light capability when I pull the fog light fuse, that’s a no go for me. I’m thinking I can put in some blocking diodes on the wiring so I keep the fog light function when the side lights/headlights are on. I would also prefer this wired into the gearshift so they come on when I take the car out of park (Canadian style). Reason for this is simple, if I’m just parked idling I don’t really want my exterior lights on screaming, “I’m idling!” Overall goal is to be as stealthy as possible while technically obeying the law, at least to a certain extent. Sorry TheWojtek, I know I was a bit harsh there. Problem is I have worked on cars that honestly have no business on the road and yet they pass inspection after inspection each year. So if these death traps are passing inspections then mine should have zero problems due to some lights… especially if I kick in some extra money for them to pass it without even being inspected (yes, I have that option available to me, but haven’t used it). I’m looking at wiring it according to the instructions in CH3M-14293-BA that link to the CJB and shifter. I can add blocking diodes on the car’s fog light wiring and on the new wiring to prevent backfeed issues. Overall looks like a simple wiring job and would be wired how JLR say to for their factory DRL kit. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory Born and raised in So Cal. Moved to the UK in 2018 for a few years. Now in Poland and looking at moving back to the UK. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
The only thing I would note here is that the Fogs would probably come on when you have the parking lights on, unless the relay has a diode built in on the coil pin, or fit an external diode. Maybe not a problem, and happy to have them on with parking lights. (by which I mean ignition off - and side lights on+) |
