Home > Technical > Adaptive cruise control issue - intermittent
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Good morning Folks,
I have raised this issue before but, thought I'd ask it from a different angle.
Now and again I get a forward sensor error, this clears when cycling the ignition, the faults are as follows:
C1A67-96 - Forward looking sensor - Component failure - internal failure (28 )
( on 01-11-2023 17:59:21 at 89912 mi )
U0401-81 - Invalid data received from engine control module/powertrain control module - Bus signal/message failure - invalid serial data received (28 )
( on 01-11-2023 17:59:22 at 89912 mi )
The second fault code, U0401-81, invalid data, could this possible be an ABS fault issue, perhaps an ABS sensor ?
I only ask as sometimes I get:
U0415-00 - Invalid data received from ABS control module (28 )
( on 30-10-2023 12:01:34 at 89757 mi )
but this is under the HCMB - Headlamp heading and at different dates/times.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #637107 Mon Nov 06 2023 9:52am
