Home > Maintenance & Modifications > Replacing leaky ACE hydraulic lines.
Gas-guzzler
United Kingdom 2007 Range Rover Sport TDV8 Sumatra Black
Just thinking about options to replace these lines as one of mine has sprung a leak. Can’t afford the option of having them replaced properly with factory lines and the labour of a body/chassis split.
One option I’m considering is replacing them with flexible lines made bespoke by a hydraulic line manufacturer like Pirtek. From what I understand of the system it must be possible with a bit of improvisation to route flexible lines to the hydraulic block and onto the anti-roll bars? Anyone looked into this or any insight gratefully received?
Thanks,
Post #636930 Sun Oct 29 2023 6:33pm
Jellis39
I’m sure it’s possible. Fittings to valve block and roll bars may be the sticking point.
Post #636938 Sun Oct 29 2023 9:43pm
Gas-guzzler
Thanks for the reply. That’s a good point. Do you know if it’s possible to access and remove the existing pipes going onto both the front and rear roll bar assemblies with the body still on? If not that’s an immediate big problem?
Post #636942 Sun Oct 29 2023 10:47pm
Jellis39
You can, yes.
Post #636999 Tue Oct 31 2023 10:25pm
PhilnDeb
Have a look at my thread " slight body lift to replace ace pipes"
Lifting the body slightly makes the job so much easier and is really not as difficult as it sounds, you just need a solid surface, 4 axle stands and 2 decent jacks.
Post #637000 Tue Oct 31 2023 11:45pm
Gas-guzzler
Thanks guys, your input is very gratefully received. I’ll have a look now.
Post #637020 Wed Nov 01 2023 11:22pm
JAMO1282
England 2011 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Hi there just wondering if you manged to solve this problem as I have the same issue and was thinking about taking the old lines into Pirtek and seeing if they can make them up? Many thanks 2011 RRS 3.0TDV6
Post #638943 Fri Jan 19 2024 8:58am
