![]() | Home > General > Illumination on rear window switches |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
My rear one's light up and can adjust the brightness with the dimmer switch, although none are what you would call exceptionally bright when turned right up, the actual rear window lock switch icon does show up brighter than the actual window switches though on the drivers door switch control panel though, however there is no illumination to the rear switches if the the rear window lock switch is on.
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 524
Everything lights up on mine as well, window switches and ambient lighting on the levers and handles. Had to replace the left rear door ambient light unit since the handle bit wasn’t working as well as the driver’s window switch since one of the mirror buttons didn’t go red when pressed or the mirrors folded in. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167
Eh up all,
I guess L/R's logic is if the rear switches are disabled you don't need to see them in the dark. |
I need to test this on my 2011 since 2010/2011 are like the awkward in between years.
Eh up NoExpert
| TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 752
Open either rear door and look for the REAR light (above rear bench side passenger head) lights up. My bet is they don't do it in any L320.
Eh up (“ Evening all” - for those who remember where that phrase comes from ! ! )
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
I could be wrong. But assuming you haven’t turned the front light off. (Hold button for 10sexonds till it flashes)
| scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586
Chaps,
Eh up
The button u hold is on the front roof light.
No, they don't unless you do the wiring mod same as on previous years. The interior lights, whether off or on auto have no bearing on the front and rear window switch light illumination, the switch illumination only works if ignition is on and lights are switched on. Cheers Col |
No lights at all when you opened the rear door? Should get the front center light, front footwell lights, cargo light and the puddle lights under the rear doors coming on, if the lights are set to on with the doors open (hold the center button a few seconds, as previously mentioned).
| All times are GMT |
