| RRSPORT.CO.UK | ||
|  | Home > Technical > Fuel Burning Heater Kit |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563      | Cheers RB. Good thoughts. My old bones are creaking a bit too much for doing much myself so I'm waiting to see what my indie comes up with. But your thoughts re age specific are taken onboard, thanks. Robin
|  Wed Oct 04 2023 5:01pm |
| TAS-M Member Since: 23 Oct 2023 Location: Midlands Posts: 6      |
 Hi all, my 2010 RRS 3.0D TDV6 is fitted with the webasto but i cannot find any settings on the menu or anywhere else. will a software update going to get the menu for us so we can set it up or do i need to fit one of them controller module on, that is wired to light, fuse box, relay etc? thank you. | ||
|  Mon Oct 23 2023 9:12am |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563      | My 2008 TDV8 comes as standard with the FBH which works automatically when the engine is started and the outside temperature is a bit low (under 5C I think).
|  Mon Oct 23 2023 10:15am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | watch from 7:50
|  Mon Oct 23 2023 11:18am |
 Hi guys, thank you for your replies, much appreciated. My home screen has not got that menu option as he says in the video "if you are luck enough to have timed climate" I guess I am not in the lucky category as my menu doesn't have that option.
|  Mon Oct 23 2023 12:47pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | First. Go here and learn how to reset the heater.
|  Mon Oct 23 2023 1:37pm |
 Thanks Andy, I will have a proper read through tonight, I have a OBD programme on a laptop that does code reading and quite a bit functions on it but not sure if i can enable the timed climate on HVAC settings, i will have to hook it up and have a go at it, thank you. | ||
|  Mon Oct 23 2023 3:51pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Unlikely, but you maybe able to read the FBH fault codes, which might say lockout, and clearing it may make the heater work.
|  Mon Oct 23 2023 4:54pm |
 Hi Andy, had some time to plug in my diagnostic scanner in yesterday and had a look, it has no function to activate or enable the times heater as you guessed. However i read the fault codes under auxiliary title and i had a fault code of B1D31 - Flame detected prior to normal operation.
|  Thu Oct 26 2023 7:36am |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | I honestly think you would be enter off with the dedicated webasto software. With this you can watch live values and check parameters,,  you can test any of the components by forcing them to run on an individual basis. More importantly,,  and quite common,, you can check to see if the heater is locked out and reset it if necessary. Lockouts happen if  the heater fails to light after a set number of attempts. This could be glow plug, fuel pump,  fan or in some cases a faulty fuel cradle.
|  Thu Oct 26 2023 8:07am |
 Hi gogsy, thank you for your reply, my webasto has never workd as far as i am aware and trying to figure out why or how to activate it, the menu has not got Timed Climate function and was looking to get it enabled with proper LR tool to test it.
|  Thu Oct 26 2023 11:42am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Good news is that webesto diagnostics are very cheap!
|  Thu Oct 26 2023 12:12pm |
 Spot on, i found all the information on disco3.co.uk with all the instructions etc, i have the adaptor but all i need is a windows laptop now, it doesnt work on mac... one of these days i will have some result lads, will keep you posted, thanks a lot | ||
|  Thu Oct 26 2023 12:15pm |
| Posting Rules
