Home > Maintenance & Modifications > P0488-72 + restricted performance
Russ2010
Some guidance required please!
I had both inlet manifolds and both EGR valves replaced last year after which the sun shone on my Rangey.
Recently, whilst on a long journey I got the restricted performance warning. As we were away, a local garage gave us the fault code P0488-72 intermittent. They did a road test with live date and the EGRs were both operating.
The fault code (and problem of restricted performance) remains and manifests itself after a bit of driving especially when the engine is required to pull a bit (up hill etc.)
Does anybody have advice on how to investigate a likely cause please?
Thanks in advance.
Post #636823 Wed Oct 25 2023 9:13am
NoExpert
Sounds like time to check connectors and wiring for faulty grounds or bad connections. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #636826 Wed Oct 25 2023 11:06am
Russ2010
Thanks for taking time to reply.
Should I focus on connectors and wiring relating to the EGRs?
Post #636840 Wed Oct 25 2023 10:13pm
