![]() | Home > Technical > Removing air suspension unit. |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9156
If you're just taking the air compressor off, you don't need to depressurise the system - the reservoir valve block immediately adjacent to the compressor separates the compressor from the rest of the system. You only need to depressurise if working on anything else downstream of that valve block i.e. everything else.
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 472
No not the compressor the air bag /shock suspension unit. Always listen to old people or when they die you will live on in ignorance.
I seem to remember that people have just loosened the voss connector a touch and let it depressurise that way. I'm sure a search here, and more importantly, on Disco3.com will confirm that. |
Thats what I was thinking but wanted to confirm,
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
Just crack the connectors (front-rear/centre valve blocks) until you hear a slight hiss then go and have a cup of tea and when you finish the system will be decompressed. 07MY RRS TDV6
| All times are GMT |
