![]() | Home > Maintenance & Modifications > Oil change |
I’m sure this will get ignored by most, but I’ll throw it out there anyway. I ran my last oil change 9,300 miles/15,000km. It was on the factory recommended Castrol Edge Professional 5w30 ACEA C1 with a Mahle oil filter. The oil change was part of changing the timing belt and oil pump. During this last change I replaced the oil cooler and am now running Ravenol FLJ 5w30 ACEA C1 with a Mahle filter. When I drained the Castrol oil I pulled a sample and sent it off to Blackstone Labs back in the US. I got the report a few weeks later and I had opted for the TBN test as well. Glad I did, the additives package was nearly spent. This brings to question how can JLR say you can go 16,000 miles on their recommended oil between oil changes? Why is the ROW oil change interval half that and coincides better with when the additives package will still have some life? Very curious. Next oil change will be at the ROW interval of 8,000 miles/13,000km and will be getting oil analysis on the Ravenol to see how it held up. At that point I’ll switch to LiquiMoly Top Tec 4500 5w30 ACEA C1 and get it tested. Then I’ll decide between the three based on the results. That is unless somebody has another oil I should try.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
I have always worked on the basis a Gallon of Oil and a Filter are cheaper than a New Engine.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
True enough, they are.
That is part of the reason to have the oil analysed, most certainly why we had a lot of out heavy haulage and construction equipment done on a regular basis so we knew if there was any undue amounts of metal particles etc. in both hydraulic and engine oils, so we had a heads up of possible engine problems etc. The cost of a SDV6 engine compared to one of the Terex or Cat engines would be peanuts. Cheers Col |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1199 ![]() ![]() ![]() |
Yep, that's why I do oil changes every 6 months/10,000km on my Puma, since our sulphur content is 50ppm in ZA. RRS is petrol, so gets it annually. I barely do 5,000km in either, but an oil change is cheaper than an engine, as you say ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
TBN is the number you want for engine oil, it tells you the oil’s capability of dealing with acid and keeping the engine clean. TAN tells you the acid level in the oil. When the TBN gets too low corrosion and build up can occur. From Blackstone: What is a TBN, and who uses it? In short, a TBN (Total Base Number) measures how much base (as in base vs. acid) additive is in the oil to offset the effects of acids coming into the oil from combustion and other sources. Scientifically speaking, the TBN is one of two “neutralization number” tests run on oils. The TAN (Total Acid Number), which is used for hydraulic and gear oil, is the other. The TBN test is useful for anyone who wants to extend their oil use beyond the normal range. Hard to see in the small image, but my TBN was 1.2 and Blackstone doesn’t recommend going below 1. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory Born and raised in So Cal. Moved to the UK in 2018 for a few years. Now in Poland and looking at moving back to the UK. |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 448 ![]() ![]() ![]() |
Having watched LR time I am now running 10w40 Always listen to old people or when they die you will live on in ignorance.
TBN is one indicator but it is a traditional one more suited to the old style fuels and oils. Without also looking at TAN and other factors, you can't simply say "that oil is done".
https://www.chevronlubricants.com/en_us/ho...s-tan.html Elsewhere on that page they also talk about the test done to check TBN and that it can give low answers depending on which test is carried out. Of course, changing oil early won't do any harm so it's owner's choice. ![]() 2008 TDV8 - it was a labour of love and is much missed |
I was fighting the urge to go to 5w40 in mine. The problem I have is mine has a DPF and 5w40 oils are pretty much all ACEA C3 (higher SAPS as well as HTHS). If I didn’t have a DPF I probably wouldn’t worry about it, but for now I’m sticking with 5w30 ACEA C1 oils. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
You could always chance your arm and use Castrol Vecton 10w40 Long Drain Oil that's supposed to last up to 120,000kms. in Merc, Daf, Volvo, Trucks etc. |
What about adding two-stroke oil? That was a big thing for a while. https://www.rrsport.co.uk/forum/topic19868...=twostroke
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167 ![]() ![]() ![]() |
Eh up all,
It's horses for courses. My SDV6 gets serviced annually or on miles whichever comes first. Serviced yesterday at 148k miles (and passed the MOT with a totally clean sheet, yippee!). It's in to its second service record book now.
Eh up
