![]() | Home > Technical > Remove pedestal sides? |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
Bit extreme but have you searched any breakers yard for a write off or scrap one where the floor is ok, and you could cut out the section you need, not sure if there are any differences in the floor pan on say a 2012/13 though as there have been a lot of changes to the part number over the years for the bodyshell. Funnily enough the part number for the floor section that is available is the same as the Disco 4, but it is still the only section available for the Disco, but it might wider your option if you did look for a breaker. Another option could be a good metal fabricating or custom car building body shop could fabricate a section for you, but I can't imagine it would cheap.
Might have different regulations in Sweden.
| pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 49
Thank you.
Is this floor inside the body shell?
I think you will find the only double skinned part will be the inner sill at the side.
You are Right Col. Only the floor and not anything below.
There are several areas where leaks can occur, if you do a search quite a few posts should turn up, I believe the main ones are the trim clips for the 'A' post outer trims on the earlier cars at least, sunroof drain tubes if you have a sunroof, can also leak in through the vent opening under the front screen scuttle panel, sure there are other areas which other members can enlighten you on.
| Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231
Hi Col,
Thanks for help with the possible source of water ingress.
Do know how to disconnect the black ventilation (very flat) tubes under the mat from the center console?
No problem when using som muscles 💪. |
| All times are GMT |
