![]() | Home > General > Rear discs and pads advice |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 502 ![]() ![]() ![]() |
Ouch. When the disc retaining bolt is stubborn I like to hit the T50 bit with a hammer a few times, helps loosen things up.
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167 ![]() ![]() ![]() |
Eh up
Eh up all,
Pull up the cup holders, look for a red pull tab, pull that back, find lock mechanism, rotate it with a coin/screwdriver, pull lever up and it will lock into place. It’s now in neutral. Reverse the steps when done. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Eh up
You’re learning more about your car than you probably wanted to. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Eh up all,
You know, it may have taken you a day to do one side, but you’ve persevered, learned some stuff and are getting through it. Pretty soon you’ll be changing inlet manifolds and oil pumps. Rest, relax and prepare for tomorrow. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Eh up
Eh up ,
Those disc retaining screws are trilobal screws, they can kind of tap/clean threads as they go in. This makes them a bit tough. If somebody put them in to factory torque, god save you. I tend to put a bit of copper spray on them to help with next time.
Eh up NoExpert
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 273 ![]() ![]() |
I find that as short a torx bit as possible, combined with an impact driver and a big hammer usually does the job. Easier with two people.
Eh up all,
