![]() | Home > General > Rear discs and pads advice |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
I can certainly switch mine off in neutral without the park brake applying.
I don’t think it was the park brake, I think the car went into park. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
If you are referring to the bedding in sequence, you don't need to cancel it after you have finished the 10 applications etc. it will self cancel or just drive above 29mph.
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 352 ![]() ![]() ![]() |
Or watch it on LRtime on the tube they did a good how to guide including bedding in |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167 ![]() ![]() ![]() |
Eh up
I not sure where some of this crap appears from, I have left my car in the garage with the park brake off for day's on end and it has never applied itself while it's been parked there. Stop over thinking it and follow bodsys bible to the letter and you will be ok.
Iv done both our D3s and my sport iv never used the bedding in proceedure just adjusted the parking brake shoes as required never had an issue.
Watch the Brembo shoes. They fit a bit odd on mine which I wasn’t happy with, so I ended up putting the old ones back (still in good condition). I installed a new LR spring kit which seemed stronger being new springs. The Brembo retaining springs are so-so, used my old ones. The adjustment procedure is easy to do, just follow all the steps. In the end I basically installed new rotors, new spring kit, adjusted the shoes correctly and cleaned things up. No more noise from the PBM and no more shaking when I hit the brakes, I’ll call it a success.
If your car vin is after BA701292 you need this kit for the springs as it contains the small red and green springs that for whatever reason were not used on the earlier cars, only £20.00 odd quid so cheap enough for a genuine spring kit, and another tenner for the genuine (SMN500012) pin/clip shoe retaining clip set.
Yes, mine is BA705XXX and I got the kit with the red and green bias springs. The kit even includes the spring/protectors for the parking brake cables inside.
Eh up all,
Yours is later, 2010=AA, 2011=BA, 2012=CA, 2013=DA, and so on.
If you are replacing the epb shoes, why would you not do the correct bedding in procedure as recommended by the manufacturer when it is so simple to do.
Eh up all
