| RRSPORT.CO.UK | ||
|  | Home > General > Rear discs and pads advice |
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134    | Hi,
|  Mon Oct 02 2023 10:31pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | Don't forget if you do fit new epb shoes, to bed them in correctly you do need to put it into the "bedding in mode" first, and follow the procedure, not just tear up the road and whack the park brake on.  | ||
|  Mon Oct 02 2023 11:03pm |
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134    | Maybe my reply was a bit short in detail   | ||
|  Tue Oct 03 2023 7:58am |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477      | I bought 2 discs and 4 pads on ebay for  £86.  Just released the handbrake and got on with it ..no problems Always listen to old people or when they die you will live on in ignorance.
|  Tue Oct 03 2023 8:46am |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up all
|  Tue Oct 03 2023 8:01pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | ''I’m even unsure if my 2012 plate will allow into P and not automatically apply the epb - need to check that''
|  Tue Oct 03 2023 8:51pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up Col
|  Tue Oct 03 2023 9:20pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | Car Configuration Files, but you do need a diag. tool to access them. Save up your pennies and buy a GapII tool, not cheap but worth their weight in gold and soon pay for itself instead of paying dealer £100.00 plus just to help diagnose a problem. Quite often come up in the for sale section. Expensive to buy but always a good second hand market to recoup some of the cost if you sell the car.
|  Tue Oct 03 2023 9:30pm |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477      | Mine is a 2009 so you have to put the handbrake on by hand...Think I put it in service mode and just jacked it up and did the job ...Ramps ??
|  Wed Oct 04 2023 6:41am |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | Well, guess what I’m doing tomorrow?
|  Wed Oct 04 2023 9:20am |
|  Wed Oct 04 2023 7:24pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | You do not need a diag. tool to do either the rear disc and pads or the epb shoes if I remember right, to put it into service mode etc. you use a combination of pressing the brake pedal and pulling/pushing the park brake switch up or down, the same applies when you want to put it into the "bedding in mode for the epb. Everything you need to know is in "Bodsys Brake Bible" just follow his instructions and you should not have a problem.
|  Wed Oct 04 2023 8:24pm |
|  Wed Oct 04 2023 10:11pm |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | I just did a 2012 Disco 4 rear park brake shoes and rotors. It allowed me to shut off in neutral and if I pressed the EPB switch down while shutting off the park brake didn’t engage. BUT, then it went into park on me at some point between shutting off and opening the hood. Ended up just pulling the emergency neutral lever under the cup holders since I didn’t want to deal with it.
|  Thu Oct 05 2023 5:15am |
| Posting Rules
 yes you are
  yes you are
 now all correctly fitted, check advanced for options and prices
