![]() | Home > General > Dynamic Response - L320?? |
Deleted |
That's what I thought. Cheers Col |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 747 ![]() ![]() ![]() |
This could've been a no-cost option for the SC, as I have seen >2010 SCs without it and a paid option for the others (as I see it on my build sheet as optional). It is different hardware - suspension struts are dual-mode, obviously more expensive. Regards etc.,
Standard fittment on the 5.0L S/C, option on the 3.0L, not avaliable at all on the 5.0L n/a engine, I think it may have become standard on both the later 5.0 S/C and 3.0L facelift cars though.
Struts are different, they have the electronic continuous variable damping and different six pin height sensors that send data to the air suspension module and the adaptive damping module. So while it’s “just a TR program” it does change the characteristics of the vehicle making it a more sporty feel in the suspension, accelerator, steering and transmission response, albeit not to everyone’s liking. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
camel_landy Member Since: 05 Sep 2010 Location: Swansea Posts: 68 ![]() ![]() |
Ah ha... Different struts. |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 417 ![]() ![]() ![]() |
"He is referring to Dynamic Response which is variable stiffness antiroll bars. DSC is standard on each and every RRS (in fact, it was mandatory for vehicles of this weight back then already)."
Land Rover called and asked for you to read your users manual again.
Whatever you want to call it, ACE or dynamic reponse was not available on 5l nrmally aspirated engines even as an option. |
You confuse DSC with Dynamic Response again, although the very thing you quoted is the simplest explanation of the differences between both. Regards etc.,
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
XKCD #386 |
