Home > Technical > Fuel Burning Heater Kit
Eaters
My FBH has given up the ghost. My Indie says its probably the spark (?) plug and that there might be a service kit for it but Webasto rep (I think) says he can't get one. A new heater is £900 or so. Does anyone know of a service kit - or any other work around to save having to buy a whole new unit? Would consider buying a second hand one from breakers but depends on how much and there's always the risk that it will fail after a couple of weeks. Anyone aware if these units are prone to failure? Oh, and before anyone says anything, yes I do use my heater a lot so its probably my fault it needs a service. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #636040 Thu Sep 21 2023 1:51pm
I think you may mean Glow Plug, used to be able to buy these separate from L/R, but they are not cheap either around (£250.00) and might be a expensive "try it and see". You certainly used to be able to buy parts/service kit's for both Webasto and Eberspacher heaters as we used to repair quite a few truck ones, but I can't for the life of me remember where we used to buy them from in the UK as it was a while ago now.
Post #636056 Thu Sep 21 2023 10:02pm
Eaters
I really am losing the plot! didn't think to just google for a service kit. I found this as a starter:
https://pbautoelectrics.co.uk/product-cate...vice-kits/
Encouraging. Now I just need to understand what I've got.
Here's the label
Can anyone interpret this for me? Robin
Gone:
MGZTT 190 2.5
Post #636063 Fri Sep 22 2023 7:23am
Eaters
A better photo.
I'm guessing that the model number is the "Artikel Nr" 9004760M Robin
Gone:
MGZTT 190 2.5
Post #636066 Fri Sep 22 2023 8:36am
Eaters
Just heard from PB Autoelectrics who say this model is made specifically for Land Rover and they cant help. Looks like its either a new one or take a chance with a second hand one Robin
Gone:
MGZTT 190 2.5
Post #636067 Fri Sep 22 2023 8:49am
If you google the part number it comes up as fitted to the VW Touran as well, if it is perhaps they do spares for them.
Post #636068 Fri Sep 22 2023 9:08am
Eaters
Cheers Col. I’ll have a look. Robin
Gone:
MGZTT 190 2.5
Post #636069 Fri Sep 22 2023 9:23am
Eaters
Col's idea might be an option. But I've just found this on the Disco3 site so posting it just for info in case anyone else has similar problems. I might try it myself or perhaps get my indie to follow this guide.
https://www.disco3.co.uk/forum/robbies-gui...ter+repair Robin
Gone:
MGZTT 190 2.5
Post #636071 Fri Sep 22 2023 11:14am
gogsy1956
Island 4x4 keep some parts for these,,, and some parts you cannot get. A glowplug is around £70,, when i had issues with mine it was the porcelain adapter that the glowplug Is attached to,,, if you can get one it would be over £100. Decided to buy a complete burner tube from island 4x4,,, £170,,, this includes burner tube, glowplug, insulator,, Inn fact most everything that goes wrong. If they fail to ignite after 3 attempts they will lock themselves out,, then you need the software and leads etc to unlock. Look on the disco site,, loads of info on there about this. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #636113 Sun Sep 24 2023 12:17pm
Eaters
Thanks Gogsy. I'll dig further Robin
Gone:
MGZTT 190 2.5
Post #636118 Sun Sep 24 2023 3:41pm
Disco_Mikey
We had one in last winter, with an "overheat" sensor fault
The sensor wasn't that expensive, but the gasket kit was Shocked
In the end, we got a used unit from a breaker for less money, fitted it for less labour, and all was well Thumbs Up
Post #636119 Sun Sep 24 2023 3:54pm
Stevepd
Found this
https://www.gentlemenofsalvage.co.uk/produ...09-to-2012 2006 2.7 TDV6 HSE in Cairns Blue.
Post #636121 Sun Sep 24 2023 5:04pm
Eaters
Thanks Gents
The latest from my Indie is that they have looked at the dismantle and clean option (Disco3 site) in the past, and say that it doesn't work. So that's their experience. They are looking for a second hand unit for me. Robin
Gone:
MGZTT 190 2.5
Post #636124 Mon Sep 25 2023 7:29am
Stevepd wrote:
Found this
Says out of stock
Post #636130 Mon Sep 25 2023 10:57am
Stevepd
Was in stock when I linked it Mr. Green 2006 2.7 TDV6 HSE in Cairns Blue.
Post #636134 Mon Sep 25 2023 4:24pm
