![]() | Home > Technical > Remove pedestal sides? |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
The whole center console ?
| pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 49
I hope I only need to remove one side if possible.
maybe post a photo of what you want to remove ? |
I don´t know if there is information in the Workshop manual about this i chapter 5.
@ Andy K, thank you for your answer.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
The front carpet is in one piece covering the full width of the floor to remove it completely you will need to remove the complete center console, I don't think you can just remove the console side panels in situ. you have to remove the whole console. You need section 501-12 of chapter 5 in the workshop manual, unfortunately for whatever reason chapter 5 does not appear to be included in all versions of the manual for 2005/2009 cars. Cheers Col |
Thank you very much Col.
I have looked at a old parts list and it does not appear to list the front floor pan separate, it is an integral part of the bodyshell, there is one listed AFD780011 but it is showing for the rear.
Thaks Col.
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 472
If you want to check then you could do what I did in my Jag ...cut a nice flap (3 sides ) in the centre and when you finished glue it back and put your cover mat on it.
I don’t recall it being a difficult connector to remove.
Thank you Andy K. I found out that it is a lever to open up the lock 👍
OK. Thanks everybody for guiding me forward.
| All times are GMT |
