Home > Maintenance & Modifications > Battery conditioners/ chargers?
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Just thinking as I won’t be doing a long commute, it may be worth while having something like a C-Tek or Optimiser battery conditioner installed on a fly lead.
Anyone else use or recommend one? 2017 5.0 v8 Supercharged Autobiography
2009 2.7 Tdi Fantom custom RRS
Post #635908 Sun Sep 17 2023 6:07pm
Lots of ppl use ctek. Not perfect reliability so keep your receipt!
Post #635909 Sun Sep 17 2023 6:17pm
"Lots of ppl use ctek. Not perfect reliability so keep your receipt!"
Can't speak for anyone else, but my ctek has survived three different countries, dragged down the road several times, unplugged by running over the lead several times and still going strong after 8 years. Smile
Post #635918 Sun Sep 17 2023 11:37pm
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
Mine is about 10 years old and has never let me down yet. Thumbs Up Thumbs Up Thumbs Up
thrown my reciept away. Whistle
CJS
Post #635920 Mon Sep 18 2023 7:39am
Pistnbroke
If you owned a classic Jag you would have your battery maintainer ON if you did not use it for about 3 days ..standard practice in Jag world.
When you start the car the tiny amount taken from the battery is put back in about 2 min ...long runs not important in fact if your battery is fully discharged the alternator will not make it 100% as the voltage is not high enough. Good practice was always to charge the battery every 3 months.
I use a £15 charger/maintainer from ebay Provided it says Pulse Repair and Maintainer you dont need to spend a fortune the electronics will take it to 15v for a short time and then hold at 13.6v Always listen to old people or when they die you will live on in ignorance.
Post #635921 Mon Sep 18 2023 8:10am
TheWojtek
I went through three units until I was sent a working one. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #635923 Mon Sep 18 2023 8:25am
Really?
Post #635924 Mon Sep 18 2023 9:11am
TheWojtek
Yeah, it was really a streak of failures. Granted, I've found a discounted returned item (although it was not advertised as returned because of being faulty), it didn't work at all. Exercising my customer rights I asked for a working one, got a replacement which kept blinking the LEDs and gave zero volts on output. Returned the 2nd one and asked for a checked, working one or my money back (meanwhile I got a 60A workshop power supply so I didn't really bothered about the Ctek any more). Eventually I got a working one and it rides with me hidden under the rear seat ever since, just in case.
I was buying from a local Ctek supplier, apparently they cover the whole CEE region so I don't know, maybe we are getting some 2nd tier stuff or what. Regards etc.,
Wojtek
Post #635926 Mon Sep 18 2023 10:01am
Putting it under the rear seat (along with the stuff already there) is an interesting idea. I wonder if my cables are long enough to remain plugged in
Post #635933 Mon Sep 18 2023 11:54am
Lindab
Ctek all the way. I have 3 for different cars. Bought a cheapo £15 Lidl one last year to see how it was. Lasted about 4 weeks then failed. Buy cheap, buy twice Big Cry Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #635938 Mon Sep 18 2023 3:44pm
scrumps
This is the one I use, as recommended by my battery supplier. Looks after my Landies and WW2 Jeeps.
https://www.bblbatteries.co.uk/product/ac1...tellegent/
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #635945 Mon Sep 18 2023 6:43pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
The JLR badged one is a CTEK
Post #635946 Mon Sep 18 2023 6:52pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
A lot of manufacturers use the CTEC and put their name on them. BMW and Bentley spring to mind
Post #635947 Mon Sep 18 2023 8:10pm
Johnrrs
I have 3, of them and have never had a problem with any of them. Ones for the RRS, another for a Z4 I have and another for a motorcycle. I also bought a cheap £15 one from Lidl and to be fair is ok but if you have a power cut for example (which we have around 4 times a year where I live) the Lidl one will not revert back to charging the battery, you need to press the buttons on the unit to start charging again but with the CTECs they revert back to charging the battery with the settings the same as before the power cut. You can also buy a lot of extras for the CTEC like a 12V socket adapter and longer charging leads.
Post #635949 Mon Sep 18 2023 8:19pm
Danv8
Just ordered the ctek one from them direct, after sending a few messages back and forth. Is it best to connect it to the main battery under the spare wheel or the start stop in the side panel? 2017 5.0 v8 Supercharged Autobiography
Post #636085 Sat Sep 23 2023 8:16am
