Home > Technical > Urgent help please
TheWojtek
NoExpert wrote:
Only applies to 2010+ Land Rovers, but you’re in luck, not the 3.6 TDV8.
Thumbs Up Another win here! Rolling with laughter Actually two wins in a row, as the L319 is a 2005. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #635659 Fri Sep 08 2023 9:52am
Johnrrs wrote:
Ok so been having a play with the car tonight and even though the CTEC charger says all is fine and dandy it obviously isn’t. When I unlock the car and open the door there is a big warning on the dash saying battery low please start engine. The car will actually start and all warning lights go off. I can’t risk going out in it unless it’s to get the battery checked and replaced if required. I may even get a company like AA or Halfords out to replace the battery as the prices seem ok(around £300 fitted)l I’ll keep the forum updated with what I do.👍
I'd just get a new battery fitted. Why mess around hoping it's ok when, as you say, it's a risk driving it.
I'm surprised to hear that Halfords will fit one - when I went to a Halfords c.6 years ago, they wouldn't touch it. I guess they've caught up with big batteries/modern systems now. 2012 SDV6 - it's missing a couple of cylinders
Post #635660 Fri Sep 08 2023 9:59am
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Andy K wrote:
It maybe because you connected the charger directly to the battery, rather than the neg lead to chassis.
Computer thinks it’s low.
Just fit the battery yourself.
Or maybe the battery is ok if the car has had little use and that is what the ctek is for
The CTEC is connected to the terminals under the bonnet not direct to the battery.
Post #635670 Fri Sep 08 2023 6:45pm
Johnrrs
Yes I’m definitely getting a new battery fitted. Just deciding when and where to take it or get a mobile fitter to fit it. Halfords s and AA will fit at home but RAC will not fit it only supply
Post #635671 Fri Sep 08 2023 6:49pm
If your not an AA member,
Will they still fit?
Post #635672 Fri Sep 08 2023 7:22pm
Farmer Chalk
Save yourself a fortune and buy one on line from Tayna. Then fit it yourself.. super super simple…
Post #635675 Fri Sep 08 2023 8:33pm
Easy but what about the coding? 2012 SDV6 - it's missing a couple of cylinders
Post #635678 Fri Sep 08 2023 11:51pm
Johnrrs
Yes they do but you get a good discount when you are a member around £30 cheaper
Post #635689 Sat Sep 09 2023 8:27am
Johnrrs
Yep I would do that but couldn’t do the coding bit
Post #635690 Sat Sep 09 2023 8:28am
Brian Considine
Far more than Halfrauds Mobile when I checked them. 2006 RRS 2.7 HSE.
Post #635697 Sat Sep 09 2023 5:54pm
