Home > Maintenance & Modifications > HELP! 05 RRS flat battery, and passenger lock won't unlock
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
let's cut straight to it. I assume a dead battery as neither keyfob will unlock it and checked the battery voltage on one fob and its' 3v so should work ok??
No lights on the dash - e.g the red one that flashes intermittently when the car is locked
and the damn passenger door lock won't unlock the car. It doesn't turn clockwise at all, and only turns anti-clockwise a bit ( ~30 degrees) but not enough to unlock the car. Tried both fobs.
I've seen some comments about powering up the car through the towing electrics? Mine has a round plug for trailer and I think a round caravan plug also? Anyone able to tell me the pins to use?
Alternatively, will the interior door locks work to unlock a door if the battery is flat? I thought they were mechanically decoupled from the door lock mechanism when the car is locked as part of the anti-hijack stuff?
For those who want the long story, I (badly) broke my right leg 6 weeks ago and didn't get around to putting the car on charge. Went down to the garage today to do that very thing, and no bueno. So my cast comes off next week and I want to drive, but currently have a supercharged paperweight... Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #635653 Fri Sep 08 2023 4:26am
The passengers door lock barrel often seizes up due to very rarely being used I believe.
Post #635654 Fri Sep 08 2023 4:55am
And if you have the 13? Pin connector, refer to your previous post!
Post #635658 Fri Sep 08 2023 8:53am
frostmotorsport
thanks team. will investigate soon and let you know how I get on.
I assume I can just power up the car via those pins and after a while it should be enough to let me unlock?
Would you connect a charger or a 12v battery/supply? Would prefer not to fry my electronics Every home should have one!
'04 Audi S4 Avant
Escort Mk II Sport
Post #635682 Sat Sep 09 2023 2:12am
Why not just connect a charger on a trickle charge for a day or so if you don't need the car straight away, can't see it will be much different than being connected with a ctek charger, shouldn't harm anything.
Post #635683 Sat Sep 09 2023 3:16am
frostmotorsport
why are things never easy...
*** STAND DOWN! I'M IN!! ***
Saw a post by Paddi saying how the door lock turns clockwise to unlock (the opposite of what the owners manual says!!) and someone else mentioned bumping the door as you try to unlock it. Welp, it worked! After about 5 or so mins of jiggling and bumping the passenger door lock obliged and allowed me into the car.
Battery is now on charge (had to disconnect the negative terminal as the extremely low voltage was freaking the car out and I couldn't stop it flashing the lights and making funny noises, even after it disarmed with teh key fob... hopeing a charged battery will fix that)
so, no voltage at the caravan plug pins 3&4. There is 1.1v at some of the trailer plug pins, so expect there is some voltage in the battery and this is just incidental.
I connected my CTek to the pins, but it throws an error. Looking at the plug, pin 4 (+ve) is at the bottom (though my plug is mounted on an angle, there is a pinout on the inside of the plug lid, so 99.99% sure I've got the right pins...) and pin 3 (earth).
It's definately a 12S plug also.
Any ideas what else I can try? I've seen someone suggest connecting the charger to the starter feed wire, but with a broken leg I doubt I'd be able to get under there and access it... that and very little space to do so in my garage. Every home should have one!
'04 Audi S4 Avant
Escort Mk II Sport
Post #635764 Tue Sep 12 2023 2:59am
Post #635766 Tue Sep 12 2023 7:45am
I haven’t seen that layout col ? Or are they different down under? Rolling with laughter
Post #635767 Tue Sep 12 2023 9:14am
There are some 15a blue fuses near the jack that could be checked.
Post #635768 Tue Sep 12 2023 9:17am
There are so many variation of the pin layout down here it is unreal, some don't even show a battery live and pin no. 4 is for the r/h indicator.
Post #635769 Tue Sep 12 2023 9:45am
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
Thank you Col - prompted me to test the passenger door lock barrel and lubricate with WD40 in case of use in an emergency. There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #635771 Tue Sep 12 2023 12:08pm
frostmotorsport
'cos you gotta look at them upside down. Get's people every time. Every home should have one!
'04 Audi S4 Avant
Escort Mk II Sport
Post #635772 Tue Sep 12 2023 12:37pm
WD40 isn't the best thing to lubricate locks with, it tends to dry out and gums them up, graphite powder is what you really need to use.
Post #635773 Tue Sep 12 2023 12:46pm
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up
Don’t want to hijack this thread by Frostmotorsport but reading with interest.
It prompted me to pop my passenger cover off and try my key in it, I certainly don’t want to be in a position where I can’t get in Big Cry
I left my car open and Gingerly tried to turn the lock iclockwise, went to about 10 past ( as per a clockface) then stopped as I felt any further would put too much pressure on the ridiculously small key Rolling Eyes I did think I heard a click but not sure.
My lock would not turn anti clockwise past 12 o’clock ( hope I’m making sense) , fired some silicone spray down ( no graphite unfortunately) still no joy of moving key any further. Therefore not able to lock the car using the key
What’s right n wrong with mine - don’t want to bust anything so stopped before being tempted to try to turn more and break something and thought I would ask wiser people than me.
Post #635781 Tue Sep 12 2023 9:39pm
Try it with the car locked and then you will know.
Alarm will go off
Maybe needle nosed plyers may help
Post #635784 Tue Sep 12 2023 10:20pm
