![]() | Home > Faults & Fixes > Slight body lift to replace front ACE pipes? |
PhilnDeb Member Since: 02 Mar 2023 Location: Swindon Posts: 17 ![]() ![]() ![]() |
2010 5.0 SC.
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 357 ![]() ![]() ![]() |
I think if you try the search function you will find your answer no need to lift the body if cutting out old pipes |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
Just as a point of interest the front ARC pipes on the 5.0L S/C are different to the oil burners, might only be the flexible hose part of the pipes though, but might be worth bearing in mind if you do find some decent second hand ones.
Yeah I am hoping to avoid cutting the pipes, as I am doing the arb bushes at the same time I think the extra space from lifting the body will help with both jobs.
I do have a brand new set here for a 5.0L, I will dig them out and post a picture of them if it's of any help.
Col, that would be helpful, thanks.they have been out of stock here for months and noone has any idea when they will be available again. Do you have any idea about lifting the body slightly, I have read about people doing it but cannot find any info on what has to be removed when only lifting a small distance.
I'm afraid I can't really help with lifting the body to replace them, there is nothing wrong with mine, I bought a spare set "just in case" as they a in short supply and probably be obsolete at some time. There is definitely some post on the subject of lifting the body and bleeding the system, probably need to use variation of wording/description in the search function,
Col, definately a good idea to pick up a set for the future! I am going to take off the wheel arch liner and skid plates and try to visually confirm that the pipes are the same and go from there, cheers. Phil. |
Couple of picture of new set of pipes for a 5.0L S/C, I would hazard a guess the only real difference between the Petrol and Diesel will be the part ringed.
Cheers Col, I have started to strip it down and the pipes look the same as the second hand ones but I am not really happy with the hoses that attach to the roll bar ( they look like they have been kinked). The good thing is the replacement set came with the valve block so I have a spare in case of issues getting the pipes out. Cheers, Phil. |
So I lifted the drivers side of the car and removed the Anti-roll bar bushes, the passenger side under the bush was very coroded so I decided to replace the roll bar.
Couple of pics all back together:- Still need to clean the wheels, new set of wheel nuts arrived today so I will do one at a time when I change the nuts.
Hi Rob, I used part no. RQA500018, not sure if your arb is the same as mine but it looks like there was one type for 05 to 09 and then one for 10 to 13, I have heard that the 5.0 SC was different but not 100%. just the hard metal pipes that attach to the front arb were different so the hydraulic shop swapped them for my old pipes., they also had to replace the hoses using compression fittings but it fitted fine and they said the fittings and hoses were rated for 3000psi.There may be more pics on my other post. I did buy a second hand set that seem to be in good condition and had the right fittings but the flexible pipes had been kinked so I didn't trust them, I think it could be a usable set if the flexible pipes were replaced.where are your pipes leaking? Are you doing the work yourself? Pics show the second hand set with kinked pipe. I have also ended up with a complete set of new anti roll bar bushes and clamps front and rears. Cheers, Phil
Rob2021 Member Since: 18 May 2023 Location: Lanarkshire Posts: 4 ![]() ![]() ![]() |
Hi phill thanks for quick reply. Looking on the parts store looks like my part number should be LR015144. In the parts picture shows a difference between pipe d between mine and yours. Mine are leaking at corner of wishbone where turns but there all quite corroded. Will be doing them myself if manage to get them. Was one thing that I noticed looked at individual part numbers of pipes in the older model that you ended up using and the only pipe that is a different part number from the newer model is pipe c which is the return according to parts diagram. Yet it was the arb pipes you had to adjust. Only saying as the older 3.6 ones only pipe c is different for mine so going to phone about see if anyone has stock of RQA500120. |
