![]() | Home > Technical > Storing tow hitch in boot - am I being stupid? |
Weird, mine fits fine.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5096 ![]() ![]() ![]() |
Can certainly remove the key from mine when hitch not fitted, and stow it in the car no problem.
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 302 ![]() ![]() ![]() |
Should be able to remove the key when detached. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9090 ![]() ![]() ![]() |
I see someone else with trim clips in their emergency kit. ![]() I have some too along with various sizes of tie-wrap, bulbs, wheel nuts, tyre inflator. Much of it lives under the rear seat along with jump leads, tow rope, fire extinguisher. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I dumped the crappy wheel brace and replaced it with a breaker bar and deep reach six sided impact socket.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
This is what happened to mine just undoing a wheel nut that was not over tight - I now use a better wheel brace.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
Is the green thing a warning triangle ? |
Gotta have the essentials in case something happens. Couple regular bulbs in the small brown box in case an LED bulb fails, zip ties stashed under the rags/first aid kit, have a pair of good work gloves in there as well. Nothing quite like the cuts of a hundred steel belts after a blowout to let you know how important gloves are in a car. Also managed to get the LR cargo net and tie downs cheap so those are in the back as well.
The LR first aid kit is ridiculously expensive for what it is. A decent after-market one would always be my choice - likewise the fire extinguisher they have as an optional extra.
"- likewise the fire extinguisher they have as an optional extra."
Which aren’t they just a Gloria 1kg fire extinguisher that sells for like £25-30? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Yeah, but it also has Land Rover on it so that quadruples the price, and then you have the very nice extra mounting bracket which also has land rover stamped on it as well so that's an extra £75.00. |
So true Col. Same with parts on the 3.0, parts from PSA are 1/2 what LR charges for the exact same part. Only difference is the box it comes in. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 316 ![]() ![]() ![]() |
The key doesn’t come out with the hook unlocked, if it’s got the original red flat head key it should fit in, mines had a replacement lock with a standard key which sticks out so I spring the lock mechanism into the locked position and pull the key out then it fits in the boot.
