Home > Faults & Fixes > Abs traction and suspension lowering fault 2008 rrs
Hullrrs
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi everyone
Just got my new rrs 2008 2.7 had it a week and love it drives spot on 110 miles on it fsh or it did for a week
All was good till I got on the motorway then 3 faults come up after about 5 mins
Abs traction and hdc car lowering and F on the gearbox car just coasts along no power
I pull over turn the car off then restart it all cleared no faults raises up and off I go again then 10 mins down the road same again
Car doesn’t store any codes and always starts back up fine
Odd thing is I can drive round towns all day no issues but soon as I’m on straight motorway same faults come up.
Searched all over the web for a solve to this but stuck
Any help would be much appreciated before I take it to the dealership
Also purchased privately so no warranty
Really want to fix this and post the results to help other owners
Post #635412 Tue Aug 29 2023 4:40pm
NoExpert
All for tires match, similar wear and the correct air pressure? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635449 Wed Aug 30 2023 2:27pm
Hullrrs
Hi thanks for your reply
All 4 tyres are same brand the front near side tyre is slightly more worn then the other but not by much
Strange thing is it was fine all day today then just as I was 5 mins from home same thing happened again
Post #635453 Wed Aug 30 2023 4:37pm
NoExpert
Definitely check the tire pressures. After that you’ll want diagnostics to help pinpoint the issue. Hopefully not water getting into the TCCM. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635461 Wed Aug 30 2023 7:26pm
Hullrrs
First thing I checked was the tyre pressures and all good there
I will try get diagnostics done and post the results
Will it show a fault even though they clear when the car is restarted??
What and where is the tccm? Is there a way to check it ?
Post #635462 Wed Aug 30 2023 7:40pm
NoExpert
Transfer Case Control Module. On a RHD I believe it is on the right side (looking at the engine) behind the battery. Sometimes water can drip down onto it and it’s not the best sealed unit I’ve seen. Pull the connector and check for corrosion on the pins.
Another possibility is a damaged ABS sensor wire on one of the wheels. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635464 Wed Aug 30 2023 9:52pm
Hullrrs
Thank you for your replies
I had the car diagnostic done came up with 36 faults in total
Garage has cleared all these for me and advised to drive see what comes back up and they will plug it in again.
Guy said it will give better idea dealing with just the actual codes that are triggered and will rescan free to diagnose.
I have driven the car 3 days and nothing has come back yet I’m sure it will
He tested the wheel sensors on the machine and all was good so don’t think it’s that
He did state most faults where bcm related
Really want to get this problem sorted so it will help other owners
Also had the battery tested came back with 11.8 v after been sat and 13.99 when running I believe that is all good
Post #635507 Sat Sep 02 2023 12:01pm
jimbg
11.8 volts is not good
 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #635508 Sat Sep 02 2023 1:01pm
Hullrrs
Thanks
I did say that to the guy but he said that’s ok for being sat overnight
Think I will go get a new battery try that
Post #635509 Sat Sep 02 2023 3:30pm
jimbg
These beasts are voltage sensitive and cause all sorts of errors to be thown up. Thumbs Up 2026 P460e Autobiography on order
2006 HSE
Post #635511 Sat Sep 02 2023 4:30pm
gogsy1956
11.8V is bordering on a flat battery,, and 13.9V running is not right. You should be seeing 14.6V at idle and a fully charged battery would be at least 12.6V. I would be investigating your alternator,, if you have access to a clamp meter you can check the charging current. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #635518 Sat Sep 02 2023 8:01pm
NoExpert
Exactly what gogsy1956 said and exactly what mine has shown for almost two years now. May need an alternator and battery cause those numbers aren’t good at all.
Mine sitting at 12.8v
Mine charging at 14.6v+
Post #635520 Sun Sep 03 2023 12:10am
Hullrrs
Thanks everyone
New battery getting fitted today and will get alternator checked Monday hopefully that will sort it out
How hard is a new alternator to fit on one of these ?
Sounds like the garage either doesn’t have a clue or wants to throw parts at it and empty my wallet
Post #635523 Sun Sep 03 2023 7:55am
NoExpert
It’s not too terrible of a job. Just a little fiddly to get access. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635527 Sun Sep 03 2023 8:52am
Hullrrs
Right then
Just been and used my voltmeter battery was 12.2 before started then went to 13.6 when running never went over 13.7 when running even giving it some revs so believe the alternator isn’t giving out enough
Just enough to keep it running
Does this sound right new alternator then possibly battery?
Post #635532 Sun Sep 03 2023 1:17pm
