Home > General > "Restricted Performance" problem.
balaenamick1948
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi everybody, I have a 2011 Range Rover Sport 3.0 diesel 87k with full Onyx body kit. I bought this vehicle two months ago and apart from a few minor glitches all looks good. However the rear light cluster was cracked and the previous owner had purchased another but not fitted so passed on to me.
This unit seemed to be identical to the old one and performed as it should but sends the vehicle into "restricted performance" mode, it seems as if the vehicle is rejecting the new body part, any ideas would be much appreciated.
Post #635401 Tue Aug 29 2023 9:57am
TheWojtek
If it works in the other light cluster configurations, it may be your RR does not see the brake light. This gives the same symptom like a damaged brake switch does. It may happen if the unit is a copy and not original, or the unit is damaged.
I would check MAF sensors and piping under the hood, tho. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #635402 Tue Aug 29 2023 10:52am
balaenamick1948
Thank you for the reply buddy, much appreciated .
Post #635407 Tue Aug 29 2023 12:52pm
A1GSS
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
Ideally, read the codes to find out what’s causing this. Might be something entirely unconnected, eg the fuel filter water sensor can throw this message too…. Laughing Which won’t be fixed by changing the tail light. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #635416 Tue Aug 29 2023 5:17pm
balaenamick1948
Thank`s for your suggestions but I`m pretty sure the issue rests with the new rear light cluster. If I refit the old one problem goes away.
I was hoping somebody on this forum may have had the same problem when fitting an aftermarket rear light cluster, surely it does`nt only rain on me Rolling with laughter
Post #635420 Tue Aug 29 2023 8:16pm
Oldandconfused
It sound like you have diagnosed the problem. Is it definitely from the same model year? The pre-facelift cars had bulbs whereas the facelift have LED's.
The cynic in me thinks that the previous owner thought that he could save money by buying a non-genuine part and on trying it realised it threw the fault code, but failed to tell you that you would need a genuine part.
I suppose you could contact him and ask for some money back, but "sold as seen..."?
I would guess that LR would want a kidney for a new one but you could try a good used one from a reputable salvage company.
Post #635421 Tue Aug 29 2023 9:33pm
balaenamick1948
Thank`s for your thought`s . My vehicle was registered March 2011 so probably a 2010 model and by this time (post 2009) already had the LED light cluster as standard so should be no issues with the old style lighting. The aftermarket unit I was given with the vehicle looks externally identical to the original unit but when I pop a bulb holder and look inside does`nt seem to posses the substantial PC board the original had.
There seem to be many aftermarket light units for sale, so assume some must be OK or this forum would be full of questions like mine.
Post #635423 Tue Aug 29 2023 10:17pm
TheWojtek
So, you have found it. Or you didn't, because the PCB is not there, but nevertheless...
Perhaps it is easily transferrable from old into new? Regards etc.,
Wojtek
Post #635428 Tue Aug 29 2023 11:06pm
balaenamick1948
I think it is possible, but with much cutting and gluing which I will only try as a last resort. I still think the answer here is to be able tell the RR electronically that the new part is OK, as the new light itself works perfectly, or maybe a course of antibiotics to help with the rejection of the new body part !! Rolling with laughter
Post #635436 Wed Aug 30 2023 9:02am
