Home > Technical > Unlocking with dead battery..?? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
There should be a blade in your key fob,, prise the small cover off the door handle (passenger door I think) a there is a mechanical lock behind it which will open the door. If you have a tow socket fitted I think you can power the car from there also,, Google the pin connections and put a battery charger on the pos and neg. That may be enough to power the central locking to get you in 2010 RRS, TDV8
Thu Aug 24 2023 11:04am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4808 |
It’s a mechanical lock. Very stiff to operate due to lack of use. Fear of breaking
Thu Aug 24 2023 1:22pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
Or pins 3 (earth) and 9 (+ve) if you have a 13-pin tow socket.
Thu Aug 24 2023 3:58pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 345 |
Thanks ..no tow socket or even wires under the boot floor.
Thu Aug 24 2023 6:42pm |
The passenger door manual lock will get you in. Take care - it can be very stiff and thus feel like you're about to snap the key. 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 24 2023 10:48pm |
